Deuce motor upgrade
Old Mar 10, 2015 | 08:30 AM
HDbranded's Avatar
HDbranded
2nd Gear
Cool Deuce motor upgrade
I'm looking at buying an 04 Deuce. It has the 88 ci and about 31,000 on it. I know frome experience that's about the time seals and stuff start going out. I would like to put a bigger motor on it... 103 or at least 96...however I'm not sure if I'd have to modify anything in order to do that?
Thanks for any input!
Old Mar 10, 2015 | 08:45 AM
dynawg1's Avatar
dynawg1
97 & 98 bore kits are as big as the cylinders/cases/crank/rods will go. Makes good power. Call Scott (Hillside), Kirby (prodrag1320), or Steve at GMR.
Or, at 31k miles, you could just fit up the cam chain tensioners with Cyco shoes, replace lifters, & install Torrington inner cam bearings and call it a day. Rocker cover gaskets, oil pump seals, cam cover gasket will be replaced as part of this job, not that it needs it otherwise.
Old Mar 10, 2015 | 09:01 AM
HDbranded's Avatar
HDbranded
2nd Gear
Nice �� dynawg1
Thanks
Old Mar 10, 2015 | 12:07 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
We were one of the first shops in the country to begin boring to 3.935" back in 2006.
Happy to help.
Scott
Old Mar 10, 2015 | 04:51 PM
Low budget Dan's Avatar
Low budget Dan
take Scotts advice build what you have you wont be sorry and you will probably spank a 103 with a tuner and stage 1 i know i can
Old Mar 10, 2015 | 06:55 PM
HDbranded's Avatar
HDbranded
2nd Gear
Thanks guys ( Scott), i will certainly give this a shot! Guess I'm gonna need a 6 sp tranny too!
DEUCE2
Old Mar 11, 2015 | 01:19 AM
HDbranded's Avatar
HDbranded
2nd Gear
Ok, here's another question... How hard is it to convert to fuel injection? I'm just wondering if it wouldn't be easier to just swap motors? IDK, just a thought!
Old Mar 11, 2015 | 06:47 AM
MarcV125's Avatar
MarcV125
Easier to give Scott a call he will go over all your options for you ...Trust me , he did my 117 and would easily use him on another build if i had the chance too..
315-495-6650 he will spend as much time as you need and answer all your questions..
marc
Old Mar 11, 2015 | 10:33 AM
HDbranded's Avatar
HDbranded
2nd Gear
Sounds good. Thanks Marc i appreciate all the info.
Old Mar 11, 2015 | 02:20 PM
dynawg1's Avatar
dynawg1
Ok, here's another question... How hard is it to convert to fuel injection? !
Why? A good tuner can easily make a carb perform very, very well. Main benefit of FI is better emissions (who cares) and it can adjust mix for different temps and altitudes on the fly. Do you travel to places with significantly different altitudes often?
