103 dyna se204 or 254e cam
Old Mar 10, 2015 | 08:30 PM
Brettg111's Avatar
Brettg111
Default 103 dyna se204 or 254e cam
Can't decide between se204 cam and the se254e. The dealer suggest the 254 for my application. I have a. 2014 dyna 103 with free flow a/c and thunderheader with seprt. Which would u guys suggest
Old Mar 10, 2015 | 09:12 PM
rgr357's Avatar
rgr357
204 for sure
cdonis's Avatar
cdonis
Imo 204, are you dead set on se cams? In a different thread you mentioned not shifting past 4800. Is that the case. What cams have you looked at and ruled out.
Old Mar 10, 2015 | 09:34 PM
Brettg111's Avatar
Brettg111
Default Cams
I'm deciding to stay with se cams cuz my dealership will warranty them and will not warranty other manufacturers . So with that bein said, I've canceled out the woods 222 and andrews. 57. So it's either the 204 or the. 254
Old Mar 10, 2015 | 10:52 PM
cdonis's Avatar
cdonis
Ahh i see!
Old Mar 11, 2015 | 11:36 AM
djl's Avatar
djl
The 204 but with a set of 1.725 ratio rockers to increase lift. You will need a good tune; the 204 can be a tuning challenge for an amateur. If the dealer will tune, don't let them load a map, tweak the map and call it good; you need a good full on tune by someone that knows what they are doing and dealers don't have a good track record when it comes to tuning.
Old Mar 11, 2015 | 05:42 PM
WillBill's Avatar
WillBill
i have se 204 cams i stuck with hd parts as the dealer said same they would warranty them but not non hd parts. the cam def woke the bike up. i had dealer tune big mistake will be getting a indy shop to tune once the weather changes and the snow melts. over all i like the 204 really woke the bike up from stuck
Superglide2012
May 1, 2015 04:12 PM
Emonster6x
Mar 26, 2012 07:51 PM
OldBoldPilot
Exhaust System Topics
20
Nov 13, 2010 07:23 PM
hadlje
May 20, 2009 12:37 PM
RoadieRider
Jul 28, 2007 08:50 AM
