Shutdown between shifts
Old Mar 10, 2015 | 06:31 PM
Herksuper's Avatar
Herksuper
Default Shutdown between shifts
So the other day, me and my bud were hitting an on-ramp and he decides he wants to play. So I hammer down through second gear into third, get up to 5000 rpm and as I go to shift into 4th...there was nothing. The engine just shut down between shifts. I clutch it, evaluate what is going on, put the kill switch to stop then back to run, hit the starter and she fired right back up while I was still rolling with the clutch in. Is there a chance I asked a little too much from my cams and floated a valve causing the shutdown? I still had electrical power and stereo still playing but engine was shut down. I've been riding since then and she's runnig like a champ, but I haven't hammered on her like I did at that time What say you gurus?
Old Mar 11, 2015 | 06:51 PM
Max Headflow's Avatar
Max Headflow
You can't over rev a HD unless someone set the limiter to something above 6500.. You are able to take the throttle and hold it wide open and not hurt the motor, providing you don't do it for too long.. Maybe a couple minutes.. I've taken an 02 RKC and wound it to 4500, WOT and pulled the clutch in on a dare.. Motor just bounces of the limiter.. My bet is that somehow the bank angle sensor got bumped and the TSSM thought the bike was tipped.. Requires an ignition / kill switch cycle to reset.. A tell tail symptom is the starter button won't work either until you cycle the kill switch or main ignition.
Add.. Another issue is that if you like to putt and don't get on it, you might have knocked some carbon loose and fouled the plugs temporarily.. I would expect that it would be hard to do with these new ignitions but I've seen it happen to old Leadwings..
GeezerGlide17
May 19, 2019 07:14 AM
Clintd
Nov 5, 2016 03:09 PM
DC2009EGUC
2014-2024 Touring Models
21
Sep 16, 2014 07:55 AM
HarleyDrifter
Aug 26, 2013 08:46 AM
Skippy97
May 30, 2013 12:04 AM
