Thoughts on dyno numbers
Old Apr 21, 2015 | 07:06 PM
qtrracer's Avatar
qtrracer
Originally Posted by Belanger14
Got it back from Harley dealer after they tuned it and it almost stalls and sputters trying to accelerate from idle into first gear, bad tune?
Harley Dealer and Tuned Correctly, don't often collide in the same sentence, LOL.
Old Apr 21, 2015 | 07:13 PM
Belanger14's Avatar
Belanger14
Had to leave it with them again over night so they can retune it, Harley tech got on it and it happened to him right away, so annoying, should Harley themselves be the best? So aggrevating
Old Apr 21, 2015 | 07:20 PM
Primetime_2's Avatar
Primetime_2
most dealerships cannot tune period! call this guy-
http://www.hillsidecycle.com/index.php/contact/
Old Apr 22, 2015 | 05:30 PM
cdonis's Avatar
cdonis
Yep, dealerships can't even get part # s right very often.
Old Apr 22, 2015 | 05:32 PM
Belanger14's Avatar
Belanger14
Ya went and picked it up today after they called and said it was alset, got on it to head home and it started sputtering again, ridiculous!
Old Apr 22, 2015 | 05:41 PM
cdonis's Avatar
cdonis
That sucks, I would think with a good tune you should you see more like 94 and 112 without the rideability issue which is more important than the dyno numbers.
Old Apr 22, 2015 | 08:16 PM
0ldhippie's Avatar
0ldhippie
Yeah with a proper tune 57s are around 95/110. Your true duals are hurting the numbers. So sad how bad most dealers are at tuning... and more
Old Apr 23, 2015 | 10:36 AM
Belanger14's Avatar
Belanger14
What would you recommend for a good exhaust to boost my numbers?
Old Apr 23, 2015 | 06:02 PM
dynawg1's Avatar
dynawg1
Forget about the dyno numbers for a moment. If you know your bike, you should have felt a significant increase in the seat-of-the-pants power after the upgrade. Did you?
Now find a reputable tuner with a calibrated dyno (meaning, at a minimum, not a HD dealer). Probably will get a good boost in the numbers and a big improvement in ride-ability (more important IMHO).
Old Apr 23, 2015 | 06:04 PM
Belanger14's Avatar
Belanger14
I picked it up today and it is finally tuned correctly!! Wow what a difference! So happy with the cams
