cams....
Old Apr 24, 2015 | 12:35 AM
fxd666's Avatar
fxd666
6th Gear
Default cams....
Between Woods, Feuling, or S&S what cam will preform the best?
Im thinking of doing a hi performance 95" with head work to match the cams. If I go s&s it will be the .585" . If i use feuling it will be their .594" an if i choose woods it will be one of their .590".
Between the three which will produce the most TQ?
Old Apr 24, 2015 | 06:11 AM
prodrag1320's Avatar
prodrag1320
each has cams that are very good for a given build & application.total lift has not as much to do with it than timing specs.figure what RPM range your looking for the cams to make power in,what compression ration will be used and match the cams to that
Old Apr 24, 2015 | 09:26 AM
98hotrodfatboy's Avatar
98hotrodfatboy
The woods cams would require a little less compression to make work than the others, produces good torque and with the 6,8 and9 series you can move your power band around to fit your riding style all good performers question is where do you want your power band. The fueling cam needs a real lot of static comp to make work and the S&S has a nice over lap and maybe a little lumpier than the other 2 with a little better exhaust scavenging. And with an lsa of 102.5 might get a little better torque at low end. The question is how do you want to ride. All three of these cams have different ranges......
Old Apr 24, 2015 | 09:54 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
A 98" with a Wood 8 can be a real ripper.
Thayers Sales & Service, Cofu, NY, tuned one of our combo's not long ago.........115/116.
An S&S .585 is no slouch whatsoever either.
A Wood 9B also will push off great power set up correctly.
Many ways to achieve a potent combination.
Scott
Galdog
Oct 18, 2012 12:59 PM
Sallyman
May 21, 2010 12:09 AM
skulznflames
Exhaust System Topics
15
Nov 28, 2008 04:46 PM
fj4069
Mar 17, 2008 07:10 AM
pauletich
Aug 10, 2007 04:53 PM
