Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I put it through the calculator. Like I said it is around 9.8:1 corrected and 10.5:1 static. Nothing outrageous.
Not outrageous, but aggressive (especially the 9.8:1 corrected CR), and will likely make your motor and its longevity sensitive to optimized tuning, fuel quality, ambient temps, and control of combustion temperature as ambient temps rise in the coming months of summer, as well as starter/battery challenges. Plan to address these issues, IMHO.
Well it took 40,000 miles to show any big signs of these things. A little pinging, a little warm, stock battery still. I did have to change the starter clutch during this time. I didn't think this was aggressive but maybe I am wrong. What do I know. Willing to take any advise. I might just put it back together with the stock head gasket. I don't think I will have enough compression ratio to take advantage of the 6-6 cams though. Might have to rethink my cam choice.
When I run the data through the BigBoyz calculator (I have my own but most use BB) I don't get 10.5/9.8; I get 10.2/9.36 which should be perfect for the 6-6 cams. 96" motor, .030" head gasket and .040" shaved off the heads, stock pistons, right? I used 0.00 deck height so actual measured might be a tad lower. 9.6 corrected is my upper limit for street motors.
As I said in my previous, mock the motor up and measure everything; measure twice. If everything fits up properly, put it together and fire it up. Don't worry about compression, stick with the .030" head gasket, you have plenty of compression for the 6-6 cams. Check CCP when you get it put together; you can do that before you fire up the motor. The quick starter bursts will help the oil to start moving. Don't heat cycle the crap out of the motor; two heat cycles, 30-60 seconds each is enough to hear any funny noises and look for any leaks. If no weird noise, no leaks, jump on for a quick run around the block. No weird noise, no leaks, take a ride and seat the rings. No synthetic oil, something like Shell Rotella 15W40 which you will drain out and change filter at about 100 miles.
"A little pinging" could be the cause of your crankpin failure, though I would think the pistons (or a piston) would be hurt as well. But the nature of pinging is that you don't hear most of It. What you do hear means it's been happening but you haven't heard it until now.
"A little pinging" could be the cause of your crankpin failure, though I would think the pistons (or a piston) would be hurt as well. But the nature of pinging is that you don't hear most of It. What you do hear means it's been happening but you haven't heard it until now. Just speculation on my part, but pinging isn't something to take lightly.
Final follow up. When I went to the dealership for parts, I told the parts guy what I finally found. He asked the mechanic about possible causes and he said only 2 possibilities. One is material defect which I ruled out with a metallurgy report. The other is lack of lubrication. I know last year while chasing this noise, I found my oil pump gouged and replaced it. I still had good oil pressure but maybe I had reduced flow. I don't know.
Anyhow got it back together and it runs fine. I went back in with the stock 0.046" head gasket which has lowered my compression ratio and reduced my power. Bike feels smoother but not as crisp or responsive as it did. It sounds good and I hope it will last more than 40k. Thanks to all who gave their opinion. Much appreciated.
Thanks for the follow up post; hope it runs forever. Should have gone with the .030" head gasket though; you would have set compression at the sweet spot for that 6-6 cam. If you have some time this summer when the heat and humidity take the fun out of a ride, you might want to make that change.
