Plug thread size different on same engine
Old Jun 11, 2015 | 07:54 PM
nukeone01's Avatar
nukeone01
Stage IV
Default Plug thread size different on same engine
I have a 2003 1200 custom sportster. When I started to check spark plugs I found one plug was a larger thread and the plugs were different. I'm new to Harley's but I'm almost positive this isn't the way it should be. Has anybody seen this before? If so what can be done to correct this problem besides buying a new head?
Old Jun 11, 2015 | 08:03 PM
Harleycruiser's Avatar
Harleycruiser
Someone has stripped the treads and re-tapped to a larger plug.
There are tread repair inserts like helicoil and time sert, or you could have the head welded and re cut, or strip the other and drill it larger.
That Or ride it, that would not bother me at all.
Old Jun 11, 2015 | 08:05 PM
senna's Avatar
senna
Someone probably stripped the threads and just went to the larger (14mm IIRC) thread size.
You could research thread serts or similar and see what size thread a 12mm repair sleeve threads into.
Old Jun 11, 2015 | 08:14 PM
nukeone01's Avatar
nukeone01
Stage IV
Thanks what would be the two plug numbers u would use?
Old Jun 11, 2015 | 08:18 PM
nukeone01's Avatar
nukeone01
Stage IV
Thanks what two numbers would u use for the new plugs?
Old Jun 11, 2015 | 08:45 PM
senna's Avatar
senna
Not knowing what size your cyl head has been oversized to, I would find the correct insert to reduce the thread back to factory size, 12mm I believe.
The kits can get expensive. so for a one time job you might seek out a local shop that could do the repair. Might be cheaper in the long run.
This is a sample of the repair kits
http://www.timesert.com/html/sparkplug.html
Old Jun 11, 2015 | 08:49 PM
Harleycruiser
Stock plugs are champion, I would find a supplier that sold them and ask them to get the same heat range resistance etc, in the different thread size.
Stock is RA8HC.
What is in there now?
Old Jun 12, 2015 | 06:53 AM
prodrag1320's Avatar
prodrag1320
if it bothers you,just go 14mm on the other head.no way ide start welding up the 14mm head to go back to 12mm.ive done that for twin cam guys with stripped heads,just machine to 14mm,no biggie
1Fordman
Shovelhead
Jun 30, 2018 03:02 PM
PPBART
Mar 6, 2010 08:58 PM
dg7080
Exhaust System Topics
Mar 8, 2008 11:09 AM
cruncher
Ironhead
Oct 10, 2007 02:16 PM
m.breen
Jun 17, 2007 11:24 AM
