Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I used the Goodridge connector but would have used the Motion Pro nylon connector had it been available when I made my cross over years ago; takes less room.
Worth checking the shaft movement in the rocker supports per the link HarleyCruiser posted; factory tolerances vary significantly from bike to bike and they were much tighter on the earlier models but still worth checking.
I have a 2003 FLHPI. The ticking you are hearing is from the play in the rockers, there are few products (i.e., rocker lockers) that are designed to quiet it, but whoever told you that's what they sound like is correct.
