Need some input
Old Jun 23, 2015 | 07:11 PM
Sunday's Avatar
Sunday
Default Need some input
Had my bike on the dyno this past weekend and I am not happy with the outcome. The bike made 120.1 HP and 125.6 ft lbs. I was expecting more with my current set up. This is what I am currently running.
120 c.i.
11.8 to 1 Compression Ratio ( SE 12.1 Pop up Pistons)
62mm throttle body and intake manifold and breather.
Hurricane Heads
S&S .640 easy start cams
4.89 gram injectors
Rhinehart Crossbacks ( still waiting on my RB Racing Pro Stock)
Zippers Chain Conversion Kit
Not sure why my numbers were so low. The 120R before me made 128/131. Any input is appreciated.
Old Jun 23, 2015 | 08:31 PM
SleepyBagger's Avatar
SleepyBagger
My 575 cams surpassed their (4.35 injectors) duty cycle. I'd think your cams would require much more and your tuner would have told you your injectors are too small. Also pushing the limits of pump gas (octane).
What tuner are you using? PV? TTS? What year ECM?
Old Jun 23, 2015 | 08:37 PM
Sunday's Avatar
Sunday
Originally Posted by SleepyBagger
My 575 cams surpassed their (4.35 injectors) duty cycle. I'd think your cams would require much more and your tuner would have told you your injectors are too small. Also pushing the limits of pump gas (octane). What tuner are you using? PV? TTS? What year ECM?
He never did mention it. I'm using a Screaming Eagle Race Tuner. I agree I'm on the limits of pump gas. ECM is a 2007.
Old Jun 23, 2015 | 10:05 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Those Crossbacks are costing you around 10-15 hp/tq, but I'm sure you're well aware of that.
Old Jun 23, 2015 | 11:47 PM
dynawg1's Avatar
dynawg1
Big peak numbers are one thing, but what did the torque curve and AFR graph look like?
Old Jun 24, 2015 | 06:07 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Post your dyno sheet. Easier to help with that....
Old Jun 24, 2015 | 11:22 PM
Sunday's Avatar
Sunday
Old Jun 25, 2015 | 07:19 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
I agree something is wrong.
We just sent a carbed 117" to the Cleveland area.
45 Mik/DTT ignition/Wood 9F's/Bassani 2 into 1/our heads.........134/136 sae.
Scott
Old Jun 25, 2015 | 09:18 AM
dynawg1's Avatar
dynawg1
Nice curves and AFRs. See what you get with the RB Racing pipe when it arrives.
Old Jun 25, 2015 | 09:43 PM
HD Bobber's Avatar
HD Bobber
Definitly low. Those numbers are sure to go up w/ that badass RB pipe when you dump those crossbacks.
I would also get bigger injectors. At least 5.3's from HD.
Rams
Sep 10, 2017 08:51 AM
jdw1
Jan 7, 2015 11:43 AM
Bambammmcd1990
May 28, 2014 11:31 PM
WideGlideFever
Oct 1, 2012 06:19 AM
62pan
Jul 26, 2011 06:11 PM
