Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I have my gatermans cranked down to around .13 at 20 flats and still getting louder. I did change to synthetic and they were not any louder at first and now the clatter is getting more excessive. They were quiet as a church mouse at .1 before. Going for some black ops as advised by a local builder. Also been hearing of some roller failures with the gatermans so being paranoid and want to get ahead of the game. Is it common to run into lifter issues with synthetic?
No, has nothing to do with it. All they need to do is pump up enough to take all the clearance up. They actually overshoot and the valve spring overrides them or the valves would stay open. Are you sure you are hearing lifters? I would rather under shoot as overshoot since if you run out and bottom them, then the valves will stay open. Maybe, the push rod is loose. Did you loctite them with non permanent grade usually referred to as blue? Ask Gaterman. They sure look impressive on there site for their claims.
No loctite. Not loose. Learned a valuable lesson with loctite when you need to pull and or readjust pushrods. Jamb nuts were still nice and tight. Never heard of one coming loose if tightened right. Gaterman himself said to go back to conventional as other have had same issues with synthetic. Im skeptical of that being the case. Sounds like the black ops are a delphi lifter "B" that gets some black coating.
I think synthetic may increase the noise in hot weather. My bike sounds 'normal' going into work at 6:00 in the morning and then sounds like a bucket of loose change on the way home (when its 95 degrees outside.)
Op, I ran the Black Ops when I did the cam swap. I don't think they were any quieter than the Chevy lifters that I run now.
I don't mind going back to conventional oil. just don't feel like dropping fresh synthetic to go back to conv oil to keep noise down if other lifters are not as noisy with either type of oil, Plus the whole made in China thing keeps dinging a gong.
If you're running 24 tpi pushrods then 20 flats will put you right at .138". You can add 2 more flats but that's it.....Evo's do not like synthetic oil. dump it......
ide pop the cover off & check your bearings as well as removing the lifters for inspection.we don't use gatermans here for this reason (noisy on occasion),we use S&S (would be my suggestion for you too),don't ever locktite p/rod jam nuts either
Just throwing thoughts out there. Forum has been round and round on the loctite. I would never use it on fine thread lock nut application or service covers. Just saw on line where the manufacturer shows using it and on youtube. I agree, if you have experience and know how to tighten them, they should not come loose. Does take a little experience since it's not like you can check it directly with a torque wrench. It's interesting that they would make noise adjusted correctly. I think of lifter noise as when you have solid lifters set a little too loose. Does not take much. You can hear .004 too much (does not hurt anything). If a hydraulic lifter is actually free and making noise, is it actually just not staying pumped up or is collapsing the total adjustment? Know I have heard a Harley with a totally collapsed lifter and till it got pumped up sounds like a rod is coming out the side.
I know my Harley with close to 50 K will make a certain tap at a certain coming off throttle position that sounds like lifters. I have always thought it was rocker arm side clearance however.
Service manual states 50W in ambient temps between 60-80* F.
North of 80 they call out 60W.
That along with an S&S lifter set at .140", you'll be quiet.
Has worked for us here, for yeeeeeeeeeears.
Scott
