Yet another cam question.
Old Aug 24, 2015 | 09:18 AM
djl's Avatar
djl
Originally Posted by cerelious
Yikes!! So then let me ask you this....if the 107, TW555 or 777 cam? And if the 106, which cam?
There are many more cams than the two you have listed. I will tell you what I just posted in another similar post. Why listen to me or other forum members that have built a few of these motors when we have two forum sponsors like Hillside Cycles/Scott and VeeTwin Performance/Kirby that have built hundreds? Call them up, tell them what you want, pick one to work with and move on; all you need is time and money.
Old Aug 24, 2015 | 12:00 PM
ntraindavefl's Avatar
ntraindavefl
As it's been said it all depends on what you like;
-real snappy off idle but not huge at high rpm
-in 4th or 5th WOT hitting 100+mph feeling like you've been shot out of a cannon.
-or have it all, strong broad low-mid range that carries out, with good high rpm hp.
Guarantee if you leave it 96 you'll regret not going 107 next riding season. If you put together a solid 107 w heads etc..you'll be on here grinning ear to ear. Do the work once the right way and the above mentioned builders are the best resource for advice and services.
Old Aug 24, 2015 | 12:56 PM
0ldhippie's Avatar
0ldhippie
The problem with your 96 is low compression which really can't be properly addressed without a piston change and high compression 96 pistons just aren't available. About any cam above 48s requires 10+/1 compression to perform properly. Thus reason for bore.
Old Aug 25, 2015 | 10:58 PM
cerelious's Avatar
cerelious
THIS! I legitimately thank you. This makes more sense than the bast majority of responses (both here and IRL). Now for the 106 or 107.....thank you all!
Old Aug 26, 2015 | 04:01 PM
djl's Avatar
djl
No disrespect intended but I believe previous posters took it for granted that you had a grasp of the physics and the factors that create cylinder compression. I would suggest that if you don't, you might want to read up on static and corrected compression as well as cranking compression.
Old Aug 26, 2015 | 08:23 PM
ntraindavefl
Originally Posted by ntraindavefl
and if you want to be limited to a lower compression range with less and smaller cam choices, the go ahead...have at it. It's your bike.
I tried to tell you first.
But thanking oldhipie is okay, I'm only a little hurt.
Everyone on here will generally give really good advice, based on experience. Good luck with it.
UTWolf
Exhaust System Topics
Nov 19, 2012 06:14 AM
BungoBill
EVO
18
Jun 6, 2012 12:19 PM
legacycycles
EVO
43
Jan 24, 2010 02:09 PM
babineaux66@msn.com
Nov 22, 2008 05:39 PM
expolice
Oct 9, 2008 08:06 AM
