Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
How blind am I that I can't find it In the parts and accessories catalog or the screaming eagle pro catalog... But i am finding something interesting... Look at the dyno charts for 103 stage 4 Race Kit... Compare it to the 96 to 103 stage 4 Race Kit... Why on earth do they have different power outputs... What the heck are you buying when you look in the catalog
You are not blind; I can't find it either. I was told the kit was in the SE section of the P&A catalog but apparently not. I know the picture I posted came from somewhere and the info source is a good one; I will keep looking and post back when I find it.
EDIT: There is a separate SE Pro Racing Parts Catalog; page 79 shows the kit but no price. I was told $1195.
Go to Kutterharleyonline.com and download the Screamin' Eagle catalog for the part # then plug in the part number on there web page and they will give you a price.
Harley has a SE120ST crate motor. Part# 192221-15. 106HP 117lb/ft of torque. for $5695.00
4.060 big bore wt cylinders
4 5/8 pro strokes flywheel & rod assembly
10.5.1 high compression pistons
titanium ss t piston rings
259 E cam
cnc ported heads with acr
58mm high flow efi throttle body.
Just got the flyer. Any thoughts
