cam change
Old Sep 18, 2015 | 06:04 PM
gmcdeadhead's Avatar
gmcdeadhead
Default cam change
when you go to change a cam in a evo motor , can you just change the cam or do you have to match up all the other gears and get them changed also ? like getting a matched set ?
Old Sep 18, 2015 | 06:10 PM
98hotrodfatboy's Avatar
98hotrodfatboy
If you are referring to your pinion and breather gears, No. just make sure you get a manual and line up the marks properly
Old Sep 18, 2015 | 09:24 PM
timsmcm's Avatar
timsmcm
If it makes noise when you will do the you may want to.
Old Sep 19, 2015 | 10:42 AM
dynawg1's Avatar
dynawg1
Very existential.
Old Sep 22, 2015 | 05:26 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Don't forget to check/set the correct end play.
Scott
Old Sep 22, 2015 | 08:32 AM
prodrag1320's Avatar
prodrag1320
best way to make sure the gears are matched is to press the gear off your old cam & press it on the new cam
kandfirsthd
Engine Mechanical Topics
May 16, 2011 08:08 PM
sglidegolf
EVO
13
Jan 19, 2011 08:51 AM
ChromeJunkie
Nov 20, 2010 11:41 PM
fiddledicksr
Exhaust System Topics
Nov 27, 2006 08:50 PM
Tltrump
16
Nov 15, 2006 01:24 AM
