Breather oil accumulation question
You know, I'm pretty sure it was a vendor here "DK Customs" that was the one who said their outlaw breather bolts would catch most of the oil and let it run back into the motor.
From what I learned here, that's incorrect. I hope that was an honest mistake, cause it would suck if otherwise. From what I read here they are very respected... I wish I could remember where I read that, just to make sure I am remembering right.
And, I REALLY like that catch can. Hmmmmmm.....
How is reaching the drain plug where you have it mounted?
https://www.hdforums.com/forum/gener...breathers.html
DK says "Here's how the Outlaw Breather Bolts work on a typical bike- the hot oily air hits the first fine mesh screen and breaks up the oil, then it hits the foam filter. The air passes thru and most of the oil gets absorbed by the filter, then drops down to the little reservoir and goes back into the head. The oil that makes it thru the filter hits the outer fine mesh and is broken up into a very fine mist."
And also: "Every-time you put the bike on it's kickstand gravity will drop the oil out of the filter & reservoir and back into the engine"
So now we have an industry leader saying the oil WILL drain back into the motor. WTH?
This is not rocket science guys and DK Customs is correct in their advertising. You must also remember that there is a big difference between Outlaw breathers and plumbed system with a catch can like those installed by GibT and rgr357.
I guess I'm just plain stupid. Here's my problem. You and others say that no oil gets back in the motor once expelled from the breather. So much so that oil can potentially gather and pool in any upward directed hoses, etc. Then DK says "Every-time you put the bike on it's kickstand gravity will drop the oil out of the filter & reservoir and back into the engine" now I may not be the swiftest man, but drop back into the engine means it goes back into the engine... I don't know how else to interpret that? I'm not trying to be dense, difficult, or a pain in the ***, really.
All oil is returned from the top end back down to the crank case where the oil is picked up by the scavenge side of the oil pump and returned to the oil pan. The head breather function is to vent crank case pressure generated by the down stroke of the piston. So, what is being vented is a mixture of oil vapor, whatever condensate may be present and any uncombusted fuel; a corrosive mix of pollutant that the MoCo vents back into the intake to meet emissions standards.
Without getting into the weeds, the head breather sit in the baffle compartment in the rocker support plate. The oil vapor is pushed up past the umbrella valve, which is a one way valve, through the filter gauze which is intended to catch the oil which will gravity drain back into the system. The vapor however, once past the umbrella valve which is now sealed by the reverse of the air flow, passes into a passage way in the cylinder head before exiting through the external breather system which routes the vapor back into the intake or to an external venting system.
So, the only place "in the motor" any oil (remember, not really a measurable quantity under normal conditions) is between the external breather and the passage in the cylinder head. As long as the motor is operating, no oil or vapor will remain in this passage. However, in the case of Outlaw or similar breather, when the bike is on the kick stand, if any oil has collected in the foam element, it can drain back into the exit passage in the cylinder head until the next time the motor is fired up.
If there is an external "plumbing" system to vent the vapor and there are lines that run "uphill", any oil that has dropped out of the vapor can collect in the lines routed up hill from the external head breather port/bolts and drain back into the passage way in the cylinder head.
If there is an external "plumbing" system to vent the vapor and the lines run "downhill" to a filter, catch can or to the atmosphere, any oil that has dropped out of the vapor will collect in the filter, catch can or drip at the end of the exit line.
There are crank vents that are one way vents that can be attached directly at the external head breather port that could prevent any oil from draining back past the crank vent if the external plumbing routes the vent lines uphill.
The main take away from all this is that we are talking about such a small amount of oil that it is hardly worth the discussion and any oil that did collect in the cylinder head passage way past the umbrella valve should be viewed as in the venting system and not "in the motor"; it is just being held temporarily in the passage way until the next piston down stroke.
Anyone that doesn't understand how the oil circulates through the TC motor, how the two stage oil pump works and how the breather system works should read the Engine Oil Flow section of their service manual.
I looked at some diagrams and see that passageway coming from the umbrella valve and baffles leading to the breather port on the head. I also saw the single oil drain next to the exhaust valve spring. There is indeed no way oil is getting from the vent to the drain back down to the bottom. So I was thinking of using one of those horseshoe looking breather vents (this: https://www.denniskirk.com/H30016.sk...ad=45713335117) that go up from the front cyl across to the rear cyl and down and out to a nipple but I don't like the thought of oil pooling in the front breather (the one going up). Unless the amount of vented gas is sufficient to blow it up and over to the other side? You think?
Sorry for the amount of time it took to beat this into my thick skull...
