Defective spark plug??
Old Oct 26, 2015 | 07:52 PM
Sierra977's Avatar
Sierra977
Default Defective spark plug??
Today replaced both spark plugs in the 120R. On advice of mechanic, running standard V-Rod plugs (10R12A/32335-04).
Heat range looks okay for street with white insulator and minor staining on top of ground electrode. Gapped 0.038" and torqued to 18 ft lbs with thin film of Permatex anti-seize. Plugs have 800 street miles on them. Shell 93 octane gasoline exclusively.
Looking at front spark plug with viewer, the center electrode appears to have a section of the electrode trying to "flake off". As this is vary hard metal, having a piece approximately 0.100" flying around in the combustion chamber seems like a bad idea and a good way to score a wall, screw up a valve seat or chip a compression ring.
Wish I could post a pic but have doubts about my ability to get an acceptable image through camera and viewer lenses.
Anybody experience a chipped or flaked center electrode?
Taking plug(s) to dealer chief mechanic in the morning to get his opinion.
Old Oct 27, 2015 | 04:02 AM
Next In Line's Avatar
Next In Line
Wouldn't it be faster just to buy new spark plugs to do a A/B test?
Old Oct 27, 2015 | 06:15 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
We use NGK's here.
No issues.
Old Oct 27, 2015 | 06:47 AM
Sierra977's Avatar
Sierra977
Spark plug(s) still worked fine so an A/B test wouldn't show anything. Potential problem is if the "chip" from the center electrode broke off and started bouncing around the combustion chamber.
Don't think the engine is having preignition issues. It's been dyno'ed at the dealership but with ion-sensing all that really accomplished is mapping the fuel/air.
Yes there are NGK Iridiums on the shelf, but I've never gotten an answer to the question of how NGK's work with ion-sensing so there they stay.
ETA about pre-ignition... The "chip" has a very sharp edge near the insulator, like the separation started there. That sharp edge surely runs hotter than the rest of the plug. If that hot spot is causing mixture to burn early and ion-sensing is doing its job, engine could be losing ignition timing and I just don't know it.
This is really a spark plug mechanical quality question. I'm good at reading spark plugs. Do it all the time for race cars. In all the years, I've never seen a spark plug in the process of flaking off a section of the center electrode. Even from engines with severe pre-ignition problems. Fractured insulators yes but not center electrodes.
Guess I need to start doing pre-install visual checks on the spark plugs. May as well start doing resistance test too... Setting the gap used to be sooo easy.
Old Oct 30, 2015 | 06:58 PM
Billyram's Avatar
Billyram
My bike runs best with NGK's.
Billy
Old Oct 30, 2015 | 11:31 PM
HD Bobber's Avatar
HD Bobber
Originally Posted by Hillsidecycle.com
We use NGK's here.
No issues.
Billy
NGK Iradium plugs here.
Old Nov 1, 2015 | 08:28 AM
Sierra977's Avatar
Sierra977
NGK Laser Iridium DPR8EIX-9 and DPR7EIX-9 plugs are in the parts box. Going to try the 8's next plug change, read the plugs then maybe move up the heat range to 7's.
Old Nov 1, 2015 | 09:10 AM
Billyram's Avatar
Billyram
As easy as it is to change the plugs I wouldn't waste money on the expensive Iridium plugs. I just use the DCPR7E.
Billy
Shooter1975
Mar 29, 2016 01:01 PM
Electra1
Apr 12, 2010 11:09 PM
Sparkplugs.com
SparkPlugs.com
Oct 20, 2007 04:19 AM
snooper0069
Aug 31, 2007 09:03 AM
LOU
Apr 26, 2007 10:31 PM
