Older Ness backplate-BAD/ Newer-GOOD
Old Nov 7, 2015 | 05:22 PM
ntraindavefl's Avatar
ntraindavefl
Default Older Ness backplate-BAD/ Newer-GOOD
If you are running an older Arlen Ness backplate maybe check for wear/cracks or damage similar to this in the pics. Note how narrow the older version is at the standoff holes closest to the opening, a chunk of mine came off with the gasket and thankfully wasn't inhaled. Not an over torquing issue, it's simply a weak design that they changed..see the older damaged pics then the newer backplate pics, huge difference.
Attached Thumbnails Older Ness backplate-BAD/ Newer-GOOD-p1020513.jpg   Older Ness backplate-BAD/ Newer-GOOD-p1020522.jpg   Older Ness backplate-BAD/ Newer-GOOD-p1020512.jpg   Older Ness backplate-BAD/ Newer-GOOD-p1020515.jpg   Older Ness backplate-BAD/ Newer-GOOD-p1020523.jpg
Older Ness backplate-BAD/ Newer-GOOD-p1020524.jpg
WVDevil
Sportster Pictures
Jul 22, 2015 04:36 PM
god61021
Apr 5, 2015 10:20 PM
MyRide7
Jan 14, 2009 07:01 PM
Softail07
Softail Pictures
Aug 9, 2008 06:39 PM
Bobberino
Jan 29, 2008 02:22 PM
