External venting 2 bikes w pics
Old Nov 7, 2015 | 06:33 PM
ntraindavefl's Avatar
ntraindavefl
Default External venting 2 bikes w pics
Set up 2 bikes, one with a kit from Dkcustoms on a Ness backplate, other is the HPI set up to match their hi flow V2 A/C unit and TB. If considering doing similar check these pics and see where I ran the hoses along the frame into the filters. The HPI kit has a cool multiple piece standoff design that works exclusively w their V2 backplate, I did have to add my own T connector to merge the 2 hoses to run one line along the frame and supply my own filter w adapter to connect ( the hoses were smaller than typical). On both I used a nylon braided cable covering I had left over to cover the solo hose running from under the AC where it connects and to the front and along the frame to filter, it matches my front end cable covers and adds better protection of the hose from heat. Think it looks good, and the cool clean air added of course.
Attached Thumbnails External venting 2 bikes w pics-img_3629.jpg   External venting 2 bikes w pics-img_3631.jpg   External venting 2 bikes w pics-img_3639.jpg   External venting 2 bikes w pics-p1020528.jpg   External venting 2 bikes w pics-p1020530.jpg
External venting 2 bikes w pics-img_3649.jpg   External venting 2 bikes w pics-img_3653.jpg
Old Nov 7, 2015 | 09:14 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Looks good, you should add some more of the nylon braid covering to the rest of the lines coming off of the breathers. Nice neat job........
Old Nov 7, 2015 | 09:40 PM
ntraindavefl
Thanks. The braided covers add bulk so wasn't sure if I wanted it off the breathers, will ponder that for sure.
Old Nov 8, 2015 | 10:48 AM
CanonSterVA's Avatar
CanonSterVA
Looks great.
Blends in well.
Old Nov 10, 2015 | 10:23 PM
djl's Avatar
djl
Dave,
The tubing looks like silicone, not fuel line. Nice and clean install; no catch can?
Old Nov 11, 2015 | 02:27 PM
ntraindavefl
Originally Posted by djl
Dave,
Thanks and bingo, good eye. That's 3/16 standard silicone tubing better for high temps and less hardening. No catch can, will see if needed but hopes are the mist will be minimal. I'll run it tad less than max fill oil and flush out the filter now and then.
Old Nov 11, 2015 | 03:44 PM
dfwhockey17's Avatar
dfwhockey17
What did you do to plug the oil drain holes in the Ness backplate?
Old Nov 11, 2015 | 04:14 PM
djl's Avatar
djl
Don't know what Dave used but some use JB Weld and a variety of similar products. I don't know the size of the drain holes in the Ness plate but the SE plate holes are the right size for tapping and installing a 1/8" pipe plug. The idea of JB weld or something other than a fastener that you know can't come loose and get sucked into the intake makes no sense to me. Check out the current thread title "Gosh Darn Screw Got Inside the Engine"; bad juju.
Old Nov 11, 2015 | 04:37 PM
ntraindavefl
Just plugged it w RTV silicone. Let it harden a few days. That was the recommendation from RK Will check to see if it's still there in a few months
Old Nov 11, 2015 | 05:09 PM
djl's Avatar
djl
It probably will still be ther; plenty do it that way. I am just a "belt and suspenders" guy and a bit on the **** side as well.
