Throwing codes need help
Old Nov 8, 2015 | 07:26 PM
Teardrop's Avatar
Teardrop
Default Throwing codes need help
My bike 2010 FLHTCU 103 with cams. I have PV with target tune. It throws codes with TT installed and without. See codes below.
With Target Tune and TT map - P0118, P0120, P0123. P1353, P1356, P1510, P1353, P2135
Without Target tune and with non TT map installed - P0118, P1353, P1356, U1016, U1040
Any ideas would be much appreciated.
Old Nov 8, 2015 | 07:43 PM
TSheff's Avatar
TSheff
Not sure what you mean by help?
http://www.fixmyhog.com/video/troubl...-codes-008010/
Old Nov 8, 2015 | 07:48 PM
Teardrop's Avatar
Teardrop
I guess I'm asking someone to point me in the right direction. I have no idea where to start.
Old Nov 8, 2015 | 07:58 PM
TSheff's Avatar
TSheff
The link I attached identifies the codes. Since you have the codes - you know how to pull them. Are you also resetting them and they are coming back? At this point I'd say you may want to communicate with the tuner people.
Some of the codes ( P1353 & P1356) are no or intermittent cyl fire and pretty sure the P1510 is related to the throttle sensor. You can also google them.
Old Nov 9, 2015 | 09:31 PM
Teardrop's Avatar
Teardrop
Thanks everyone. Looks like I'll be taking the bike in to the shop. I hate electrical issues.
Old Nov 10, 2015 | 12:04 PM
todd-67's Avatar
todd-67
Just a thought but did you unhook the TPS sensor wires on the back side of the throttle body and inspect the pins. Often times these corrode or get fretted. Carefully cleaning them and applying some dielectric grease on them often fixes those TPS codes.
Old Nov 18, 2015 | 03:13 PM
Tripleshot's Avatar
Tripleshot
PV will tell you the codes to help you diagnosis the problem. Its in there and may be a simple fix. You can get code definitions from the manual too.
Old Nov 18, 2015 | 08:13 PM
14GuineaPig's Avatar
14GuineaPig
You should be able to look up your code here:
http://www.fuelmotousa.com/p-29661-h...es.html#pcodes
CarlFitzwater
Jan 21, 2018 11:26 AM
ckfansler
Jan 2, 2015 05:35 PM
tennman0258
Oct 14, 2014 07:09 AM
tennman0258
Oct 6, 2014 11:46 AM
masterblaster
Mar 19, 2011 04:06 PM
