New build issues. Please help!
I have just installed a new 113ci screamin eagle kit, 50mm se intake, 110ci se heads (ported and polished internals) 49 g/s injectors. It also has the vance and hines fp3 tuner which i emailed them the specs and they sent me a map to upload.
once i finished the build it fired right up, it will only start when cold, when hot if you try to start it will puff black smoke and backfire through the air cleaner as if it is running very rich. It shows the p0108 code map sensor fail high/open port. I have changed the map sensor and also o2 exahust sensors.
any advice would be much appreciated
If you find nothing, you might try starting the bike without the FP3. If that fixes it, it still might not be the tune in the FP3, it could be electrical and you'd want to replace the unit or go with a tuner that actually programs the ECM rather than piggybacking. If it does it with a different FP3, than the only thing I can think of is that the calibration is so far out that it's taking the read at the incorrect time and seeing a high voltage. The Harley ECM takes reads of the sensors based on crank position and cam profiles have a lot to do with how the OE calibrations are set up. When the cam profile is way out of what the programming thinks it should be, things can get pretty weird.
In most of these cases that I have seen, recent work has been done and there is a damaged or loose connector or wire somewhere in the mix.
Also - make sure that the throttle shaft is not broken in the throttle body.
Riding an untuned bike is like eating the batter before baking the cake.
Bob
