map sensor high
Old Dec 31, 2014 | 01:25 PM
ckfansler's Avatar
ckfansler
6th Gear
Default map sensor high
Maybe someone can help, just installed fi2000 powerpro on 2007 ultra classic what a difference. Now engine light staying on getting code P108, where is the map sensor located on bike. Thanks
Old Jan 2, 2015 | 09:35 AM
Mr. Wizard's Avatar
Mr. Wizard
It's on top of the throttle body. Don't look at the MAP sensor before you unhook the tuner and see it there is a conflict first.
Take the tuner off, clear your codes then see if the code comes back.
Old Jan 2, 2015 | 05:35 PM
BVBOB's Avatar
BVBOB
The "high" normally denotes a shorted wire while a "low" code will be a broken wire.
CarlFitzwater
Jan 21, 2018 11:26 AM
edgeofinsanity
Mar 25, 2012 02:56 PM
GlideWylie
May 8, 2011 06:18 AM
shooter5502
Jun 13, 2010 10:50 PM
shooter5502
Jun 13, 2010 11:27 AM
