Build question
Looking at the bigboyz compression calculator. It looks like static compression is 9.87:1 and corrected compression is 9.69:1 without knowing deck height. Is this acceptable with a good tune?
So, you can wait for Kirby or perhaps put your question to the forum. Just a friendly suggestion.
AMS in dallas does a nice and economical 105" package with heads setup for touring bikes.
It would be nice if you gave us the cam specs on your cams so we dont have to look that up.
But 10.0 comp or higher may or may not be an issue with detonation (esp on hot days) and proper cam selection is key because too little duration & overlap with result it too high cyl pressure leading to detonation but choosing a cam to run with 10-10.5 comp thats got the right amount of duration/overlap LSA etc it key esp on today lower octane 93 fuel with 10% ethenol.
This isnt 1970 with Sunoco 100-102 octane leaded fuel avail at the pump!/LOL!!!
Some states do allow Sunoco unleaded 100 octane fuel to be sold at the pump ,but unfortunately for me not in NY where i live.
Tip,when you get this build done if it does happen to detonate on hot days on 93 pump fuel
(excessive engine heat can increase it's octane requirement) try this that reduced oil temp 50+ deg
(also reduced engine temp @ same time too) which can stop detonation on hot days due to significantly
reducing oil/engine temp .
I reduced oil temp 50+ on hot days (made huge improvement in the engines/bikes perf on hot days) when i installed Wards twin cooling fans along with an ultracool oil cooler also having twin cooling fans at the same time that working collectively together reduced oil temp 50+ deg f resulting in many positive results 1 of which was stopping detonation thats a reall issue with stock HD's that have very mild cam timing with low duration along with little to no over lap too resulting in higher cyl pressure even on stock motors like 96" with 9.2 compression.
Could run " real lead octane booster " (same lead used ti increase octane in fuel 40yrs ago) that can get pricey and can cause issues with 02's & EFI.
Heres a link to the real lead booster if you would like to check it out.
I have been using it for many yrs with great results classic muscle car motors i work on & or maintain for other people inc my own 1969 chevelle SS396 with big block chevy 4spd i bought from the original owner in 1978.
http://www.wildbillscorvette.com/OctaneSupreme01.htm
scott
