120R vs 120ST
Old Dec 3, 2015 | 05:48 PM
abidzip's Avatar
abidzip
Originally Posted by fuelmoto
As several noted the ST is the emissions compliant version on the 120R engine. The only major difference is the ST motor uses SE-259E cams and includes some extras such as the throttle body, the 120R uses SE-266 cams. Both engines are very good platforms and are capable of making big power with just a few modifications. I would however recommend replacing the SE lifters before running either of these engines as we have seen several catastrophic failures, and we caught one here on the dyno just before before it expired. The valve springs are also a weak point.
Your scaring me Jamie, how many miles were on these engines when catastrophic failures occurred with the lifters and were the owners beating the crap out of it in you opinion?
Old Dec 3, 2015 | 07:42 PM
Sierra977's Avatar
Sierra977
The following were done to my 2014 120R before I took delivery:
1. SE roller rockers
2. Woods lifters
3. Offset rocker plate
4. 0.030" head gaskets
5. SE +1.5 quart oil pan
6. JAGG fan-assist 10 row oil cooler
7. Changed valve springs from 3-coil to 2-coil
8. SE Variable Clutch
9. Other things I can't remember right now...
Works damn good.
Old Dec 3, 2015 | 10:35 PM
C.H.L.'s Avatar
C.H.L.
Originally Posted by OldEnuf2NoBtr
There are tons of big inch motors running around that use the stock HD cam plate and oil pump with no issues what so ever. Matter of fact, a lot of builders swear by them.
My builder said he has good luck with these stock parts ....
Old Dec 4, 2015 | 11:29 AM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Some have seen issues with less than 10K of normal use, we have one here right now that the lifter came apart and destroyed the cases.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Dec 4, 2015 | 11:30 AM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
2. Woods lifters
Works damn good.
Nice setup!
Old Dec 7, 2015 | 08:56 AM
grbrown's Avatar
grbrown
The 120R was launched as a promotional engine for drag racing. I suspect demand for it for road use, prompted the MoCo to capitalise on that and produce the 120ST version. That would also explain the lack of warranty on the 'R' and use of stock production parts on the 'ST'. The ST may possibly be helped by S&S T124 sales, as they also have two versions of that, with different cams and CR.
RC07ultra
Engine Mechanical Topics
Dec 6, 2018 03:39 PM
Lundee
Exhaust System Topics
Feb 8, 2012 09:29 PM
JohnCA58
Softail Parts
Aug 26, 2009 02:11 PM
JohnCA58
Touring Parts
Aug 26, 2009 02:09 PM
JohnCA58
Aug 24, 2009 03:14 PM
