Cylinder wall scratches
Old Jan 2, 2016 | 08:42 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by prodrag1320
I hardly think anyone would ever set any build to have 160ccp
Right.... your cam corrected compression would be like 8.0:1 Don't know any one that would build that, and why?
I would suspect something going on there....check with the indy that originally built it to get beginning build specs.
Old Jan 4, 2016 | 10:05 PM
mbierbac's Avatar
mbierbac
Could have been caused by excessive heat or lack of oil on initial start up. How is your pressure? Make sure you change the oil often during break in. I would not be too concerned I had an Evo with the same issue did a cylinder leak down test with decent results. The cylinders looked worse than they actually were. As long as you getting good compression
Old Aug 1, 2021 | 02:48 AM
baldy42's Avatar
baldy42
Stage III
Originally Posted by Hillsidecycle.com
As already mentioned, hard to determine until dissassembly.
A leakdown test may be of help.
Those bore scopes lead one to believe that you are looking at a boulder, or the Grand Canyon when in reality nothing even close.
We have 2 of those here............best place for them is to stay in the case they came in.
Scott
so true **** those boroscopes off
Old Aug 1, 2021 | 08:14 AM
bustert's Avatar
bustert
how did the carbon build up look?
air cleaner up to snuff?
regular maintenance?
wrong cut on walls on install? seen this one many times.
confined to one area?
Old Aug 1, 2021 | 09:03 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Old thread.....
Old Aug 1, 2021 | 01:01 PM
bustert's Avatar
bustert
hummm
maybe the date needs to be in a highlighted color.
i do notice you do have a sharp eye. mine not so great!
Old Aug 1, 2021 | 05:48 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Originally Posted by bustert
hummm
It would be nice if the forum would automatically lock the thread after a certain elapsed time. We all inadvertently stumble into a long dead post...
GibsonSG
Engine Mechanical Topics
25
Jun 13, 2020 10:06 PM
Gordon61
Mar 21, 2016 06:40 AM
exactlynowhere
Oct 3, 2015 09:07 PM
Bagger_Vance
87
Jun 6, 2015 03:24 PM
freud
Shovelhead
Dec 11, 2013 02:26 PM
