Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Well I pulled the heads to get them ported and skimmed to 10:1 cleaned up the cylinder tops and the pistons till they are spotless, tightened but not torqued the cylinders down and measured the deck height ...this is what I found...
Machined straight edge across the top front to back and the piston is down (above the pin) 0.008" but, the piston is tilted in the bore - deck height at the front of the piston is 18 thou at the front and 2 thou at the back !! Cylinder bores look normal and can still see the honing and no sign of scoring at all.
I can actually feel the piston move left to right (on the pin) a touch when at TDC and with it to one side I can easily get a 6 thou feeler gauge between the piston and the bore down to the top ring at the other. The service manual says to replace the piston if more than 3 thou gap piston to cylinder.
Bike is a 2014 softail, 103, with only 8500 reasonably gentle miles. Is this right? (or typical anyway). Oh, and is 8 thou a bit excessive for the deck height, think I read 5 was typical?
pistons are tapered,with the top being smaller than the bottom.pistons are measure at the bottom of the skirt with a micrometer,cylinders are checked with TQ plates & bore gauges.when checking deck hieghts,check at the wrist pin as the piston will have some rock front to back.if you are concerned,i would remove the cylinders and check them properly
Pistons are barrel-shaped and are much smaller at the top.
Micrometer measurements are performed across the widest part of the skirt.
Then a dial bore guage is set, and the clean cylinder is measured.
Scott
