piston clearance issues
Old Nov 30, 2011 | 04:28 PM
barrygxl's Avatar
barrygxl
Stage IV
Question piston clearance issues
just bought some wiseco forged reversed dome pistons for a 1200 conversion. anyone know piston to cylinder wall clearance i should have? thanx, baer.
Old Nov 30, 2011 | 08:17 PM
Von_Zipper's Avatar
Von_Zipper
With watercooled engines I used to rebuild and modify the rule of thumb was simple, put piston into cylinder and let it drop (no rings). It was supposed to fall slowly. No fall - too tight, drops like a stone - too loose.
Old Nov 30, 2011 | 10:24 PM
Scuba10jdl's Avatar
Scuba10jdl
I know in the car world, .002 to .004 is pretty standard for naturally aspirated builds with forged pistons and a little more clearance for boosted engines. You can get about .0015 to .002 for cast pistons.
Your best bet would be to call up Wiseco and talk to someone. Under their FAQ's they had this to say:
"The factors that affect this are cylinder wall thickness, whether the block is filled, the overall compression height of the piston, piston material and thickness, and whether a marine engine is to see fresh-water cooling. Most small blocks get .004 piston to wall clearance and most big blocks get .005 due to the use of our 2618 high-strength alloy. For heavy blower and nitrous applications, Wiseco recommends adding .001 to the standard clearance. Special note: Clearance numbers are obtained from measuring the largest diameter of the piston, typically at the bottom of the skirt. All measurements should be taken 90 degrees from the pin centerline."
Old Dec 2, 2011 | 08:40 PM
barrygxl's Avatar
barrygxl
Stage IV
Default piston clearance issues
thanx guys, that is reaaly excellent info. baer.
Sisu
Engine Mechanical Topics
Oct 20, 2016 01:35 PM
Gordon61
Mar 21, 2016 06:40 AM
freud
Shovelhead
Dec 11, 2013 02:26 PM
JONNIEROCK
Oct 5, 2013 12:48 PM
jdusty21
Ironhead
Jun 29, 2007 12:31 PM
