question about compression ratio
Old Feb 10, 2016 | 08:24 PM
jeffbetrollin's Avatar
jeffbetrollin
Default question about compression ratio
Hey guys I'm really ignorant about engines. All I know is I like to wheelie and go fast haha. I currently have a little 88ci 2006 fxd and I've been beating the hell out of it. And I'm ready for more power but I'm on a budget. I have a guy that is going to. do my build just going with a SE 95" kit with the 203 cams that are included in the kit. My mechanic is recommending I do a 30 head gasket and mill the head down .025 he says that combo will help raise the compression ratio. He is also doing a mile port and polish.
I have a buddy with a softail he has a 95" with 10.5:1 comp and it's a bitch to start sometimes. I was wondering where I would be in relation to his bike
Old Feb 11, 2016 | 11:23 AM
djl's Avatar
djl
Your builder has it about right but why not just bore your cylinders, install SE cast flat top pistons, use the .030" head gasket and SE204 cams or an aftermarket like Andrews 48 or 37. The '06 heads flow better than earlier heads and don't require much work; just some cleanup, bowl blending and a good multi angle SERDI valve job.
Boring your cylinders and buying SE cast flat top pistons will be cheaper than buying the Stage II BB HD kit and doesn't lock you into the SE203 cam which is not such a good pick for a Dyna. The SE kit components are not "matched" so your builder should torque up the cylinders in torque plates and check piston to cylinder fitment before assembly; if out of spec, he can return the parts. Not an issue when boring your seasoned OEM cylinders to fit a new set of pistons.
Old Feb 11, 2016 | 11:29 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Bore to 98".
Andrews 57's
Our Stage II Heads.
Scott
Old Feb 11, 2016 | 11:52 AM
jeffbetrollin
My budget is. Around 2k I can get the se kit for 1k. Labor is going to run me 7-800 I have a pcv for tuning already. And dyno tune is going to cost me 100$ I'm getting the labor and tune done cheap (atleast imo) lol. Because I bring alot of work into my mechanics shop so he always cuts me a deal. If boring my stock cylinders and buying se flat top pistons will save me money I'm all for it! But how much would u say it saves? And thanks again for the reply.
Old Feb 11, 2016 | 12:35 PM
djl's Avatar
djl
Round numbers, boring for new pistons in lieu of the HD StageII BB kit would save about $400, depending on what boring, fitting pistons and gapping rings cost in you area; runs about $120 in my area. I figure for about $600 you can have your cylinders bored, buy and fit new SE cast flat top pistons, buy a cam set and installation hardware.
BTW, you might consider installing compression releases as part of the head work. The $400 you might save on the piston/cylinders is almost enough for a basic "street" port on your heads.
Old Feb 11, 2016 | 08:36 PM
Stych's Avatar
Stych
Or S&S Easy Start cams in leu of compression releases. Not sure which is less money though.
Old Feb 12, 2016 | 09:27 AM
jeffbetrollin
What kind of power is your 06 making with 10:1?
Old Feb 12, 2016 | 09:57 AM
djl's Avatar
djl
You need to focus on corrected CR and/or CCP; the motor (sorry Scott) does not see static CR. The motor operates on dynamic (corrected CR) which are functions of the timing of the close of the intake valve. Static could be 10:1 but with low CCP and lagging power in the low to mid range. Install cams with an earlier intake close and static stays the same but CCP increases. Compression = torque.
Old Feb 13, 2016 | 01:54 PM
Stych's Avatar
Stych
I haven't had the bike on a dyno, so I couldn't give you any numbers, but I'm very happy with the power the engine is making. Happy enough in fact, that I may never even bother to dyno it, but we'll see...
otto76689
Aug 26, 2016 02:56 PM
RK14SGS
2014-2024 Touring Models
13
Jan 19, 2015 05:06 PM
twism_23
Exhaust System Topics
Nov 16, 2012 03:07 PM
Not E'nuff Harley
Engine Mechanical Topics
Apr 24, 2012 09:32 AM
mplecha
11
Apr 1, 2010 01:21 AM
