Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
You ordered it on the 11th to South Korea and already have it installed and broken in? Impressive.
Usually it takes about a week to recieve parts ordered here from U.S,
but something was wrong in my ordering so it tooks another week....
The installation took about 8 hour actually.
That's about the hours a shop would charge you to install all said and done. How you like the 585 cams, does that kit come with the SE heads as well?
About 585 cams, I can't compare with other ones because I didn't use them before but only stock ones.
If comparing with stock ones, they are concentrated on very low end torque as the HD advertising.
Although extra volume(7ci) and compression ratio(9.7->10.2)
boost torque whole range of RPMs, I can feel that mush more powers are added at low end RPM.
The 110ci stage3 kit (92500035) doesn't come with SE heads
but uses stock heads.
Thank you!
You really have very nice one !
The picture shows the bike with beautiful blue...
And blue hats on bike's head and rider's head....
Looks cool!!
Thank you!
Looks cool!!
Thanks, check back in after you have riddenm some miles on that 110 let us know how it performs..
