Quick pushrods help
Old Mar 20, 2016 | 01:44 PM
drumguy460's Avatar
drumguy460
Default Quick pushrods help
I installed woods tw777 cams without a hitch nice and straight forward install. When I was installing my quick install adjustable pushrods, I put the front cylinder intake lifter at the lowest point while the exhaust lifter was all the way up. After installing the intake pushrod I rotated the engine, till the exhaust lifter was all the way down and installed that one. Now my question is, after going over the instructions, I realized that both lifters needed be at the lowest position. I did NOT start the engine yet. Did I do this wrong? Should I take the pushrods back out and do them again so I know they're correct. Thanks guys
Old Mar 20, 2016 | 06:09 PM
ntraindavefl's Avatar
ntraindavefl
Did you rotate it after the intake lifter bled down?
Old Mar 20, 2016 | 06:15 PM
djl's Avatar
djl
Better to adjust pushrods with the piston at TDC on the compression stroke; lifter will always be on the heel of the cam.
drumguy460
Engine Mechanical Topics
Mar 21, 2016 02:25 PM
AllenW
Exhaust System Topics
11
Apr 23, 2013 08:33 AM
stro1965
Apr 1, 2013 08:18 PM
trnewman
Mar 26, 2013 04:29 AM
klaybus
Mar 7, 2011 07:12 PM
