Loud Tick At Idle
Old Mar 30, 2016 | 05:01 PM
RoadGlide_13's Avatar
RoadGlide_13
2nd Gear
Default Loud Tick At Idle
New problem started about half way through last summer. I'm hearing a louder tick when im sitting at idle. When I'm on the bike it sounds like its comming from the primary. I checked everything with a stethascope cams pushrods lifters rocker boxes even the primary cant hear anything out of the ordinary. But i put the stethascope on the frame and its really loud. Im baffled. I looked for loose bolts on just about everything. Even adjusted the pushrods a couple times. Im running a 2012 fltrx 103 with woods 555 cams comp cams adjustable pushrods and v thunder (dalphi) lifters a V&H propipe and the SERT (should have gotten dynojet) did all the work myself never had problems and the tick came up randomly. Never changed anything to make it happen. Could it be my compensator? I have 45,000 miles on it. Any ideas? Anything would be much appreciated. Thanks ~Bubba
Old Mar 30, 2016 | 06:24 PM
djl's Avatar
djl
Check out the linked post.
https://www.hdforums.com/forum/engin...terchange.html
Rocker shaft movement could be the problem. There are two similar products, both cheap fixes for a very common and annoying problem. Tick could be from a variety of sources but eliminating rocker shaft movement as a cause is quick, easy and cheap to address; I would look there first............
Old Apr 3, 2016 | 08:49 PM
FlaHeatWave's Avatar
FlaHeatWave
Since you said that it sounds like it's coming from the frame, could the front exhaust heat shield be hitting on the footboard mount??
Old Apr 3, 2016 | 09:19 PM
ROCKOUT Rocker Products
Sponsor
Here's some before & after videos one of my customers took, ticking problem solved. Does it sound like this?
https://www.hdforums.com/forum/touri...l#post15000939
For ROCKOUT information & purchasing please click the links below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Apr 3, 2016 | 11:04 PM
74shovel's Avatar
74shovel
Take your timing cover off and take a look see. I had a chain tensioner shoe worn out, at the same mileage. I kept thinking I had a bad lifter. The shoe had worn down so that the piston was wearing against the chain. Only clattered at idle( lower oil pressure ).
Old Apr 4, 2016 | 01:00 PM
djl's Avatar
djl
Good advice; look there next......
lhgdale
Mar 5, 2019 01:18 PM
dynasnow
Engine Mechanical Topics
Sep 29, 2017 09:56 PM
dforeid
Mar 21, 2017 08:00 PM
reptile80
Feb 9, 2015 02:06 PM
gipper
Sep 30, 2013 12:21 PM
