124" rod length differences
Old Apr 7, 2016 | 02:25 AM
1911flhx's Avatar
1911flhx
Default 124" rod length differences
Quick question to the motor guys here. What is the differences between building a 124"er using the S&S hot set up kit with the longer rods, vs building one based off a 120R with the shorter rods? Going to back to my small block Chevy days, the longer rod definitely affects the piston compression height. It looks likes the wrist pin is in the oil ring groove on the S&S site. Not to mention the S&S cylinders are taller than stock by 0.96. I know it affects the intake manifold length, but does this affect exhaust fitment? Thanks.
Old Apr 7, 2016 | 03:25 AM
Next In Line's Avatar
Next In Line
Bore diameter.
Old Apr 7, 2016 | 12:46 PM
1911flhx's Avatar
1911flhx
Both are 4.125 bore
Old Apr 7, 2016 | 12:47 PM
1911flhx's Avatar
1911flhx
124 built off 120r with 4.125 jugs
1911flhx
Apr 8, 2016 07:07 AM
02fastdyna
Engine Mechanical Topics
Mar 11, 2016 11:51 AM
jmb79
Nov 6, 2014 07:23 AM
GordFXE80
Shovelhead
15
Sep 18, 2014 11:02 AM
olsenam0822
EVO
Oct 17, 2012 01:43 AM
