103 lifter question
Old May 6, 2016 | 07:45 AM
timber0472's Avatar
timber0472
Default 103 lifter question
Hey guys just got my hands on a 2013 street glide. Changing cams out to some 2nd hand woods tw222 that I picked up and I've read that some suggest changing lifters. Not trying to break the bank with $300 woods but the standard s&s ones look reasonable.
Any suggestions?
Thanks.
Old May 6, 2016 | 08:13 AM
nhrider1's Avatar
nhrider1
Any suggestions?
Thanks.
Definitely change the lifters. 13's had -C lifters made in mexaco and subject to failure. S&S standard are good lifters and should serve you well.
Old May 6, 2016 | 10:44 AM
harley_jeff's Avatar
harley_jeff
When I did my 103 build I went with the Woods lifters. They were super noisy and then I switched to the S&S ones. I already had the S&S roller rockers, so I thought why not try their lifters. Much quieter than the Woods. So, go with them. I asked the same question on here several years ago and another product with positive comments were the Gaterman lifters.
Old May 6, 2016 | 12:32 PM
timber0472's Avatar
timber0472
Which s&s do you suggest? There's 3 kinds. Motor is mostly stock.
Old May 6, 2016 | 12:43 PM
qtrracer's Avatar
qtrracer
S&S standards
Old May 6, 2016 | 02:58 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
S&S std lifters.
We stock them, and the premiums as well.
The std lifter is tougher than most suspect.
Scott
Old May 6, 2016 | 03:39 PM
harley_jeff
As I recall, I used the premium ones that did not have the travel limiters.
Old May 7, 2016 | 05:35 AM
Hillsidecycle.com
Sponsor
We use the non-limiter lifter here.
Scott
Old May 7, 2016 | 02:00 PM
timber0472's Avatar
timber0472
Originally Posted by Hillsidecycle.com
S&S std lifters.
Scott
If I'm using the s&s quickee adjustable rods what is the recommendation for adjustment? I know some say the woods 222 is noisey.
timber0472
May 16, 2016 09:19 AM
linewatch
Engine Mechanical Topics
Dec 19, 2015 10:55 AM
1911flhx
Jun 29, 2015 05:17 PM
txphatboy
Mar 18, 2015 07:06 AM
1320str8_liner
Feb 3, 2013 09:53 AM
