Do these dyno numbers seem low ????
Old Jun 15, 2016 | 07:42 PM
ScottyD1's Avatar
ScottyD1
friend of mine just did a 107 build from Kirby(prodrag), his heads, s&s 585's, hpi 55mm tb with stock injectors and a v&h propipe, tuned by Dan Thayor, made 125hp and 117 ftlbs of torque
Old Jun 15, 2016 | 07:48 PM
Gesjr6's Avatar
Gesjr6
These are the types of builds that are making me wonder why my hp numbers came back so low. If I was to throw on a propipe I don't see myself gaining 20 hp
Old Jun 15, 2016 | 08:19 PM
ScottyD1's Avatar
ScottyD1
my buddy was going to buy a d&d but kirby said to use a propipe
Old Jun 15, 2016 | 08:23 PM
ntraindavefl's Avatar
ntraindavefl
The most obvious issue nobody mentioned yet is the model bike
Breakouts dyno very poorly on peak hp numbers. The weight of that wheel along with a counterbalanced motor is a power robber.
U can't have it all... Fat wheel, heavier softail, swoopy non performance pipe and basically a whole model image revolving around appearance and then want killer Dyno numbers too. Not how it goes sometimes. Sorry
Old Jun 15, 2016 | 08:28 PM
Gesjr6's Avatar
Gesjr6
I guess it never ends when chasing dyno numbers. At first I was a little bummed that I spent a **** ton of money and only gained about 14 hp from where I was with just cams. I see all these post from people making 100 plus hp out of 103's without spending half the money I dropped on my build so my knee jerk reaction was to be disappointed that my hp numbers was so low on a 107 build with numerous other upgrades. I have decided I'm not gonna change pipes just to chase dyno numbers tho . It's just a street bike tho I do think I'm gonna take it to the track a few times this summer.
Old Jun 15, 2016 | 09:03 PM
djl's Avatar
djl
Dave is right about Breakout tunes; however, your numbers are low for the build. I have seen 103" stage kits heads, cams, larger T/B make better numbers; not mucj but all over 100HP. Most made decent numbers but had rideability issues that were solved, along with better numbers by pulling the SE cams, dropping in a set of S&S 585s and retune. Numbers didn't change much but rideability issues were resolved. None of this is relevant to your situation, just wanted to add to what Dave has pointed out; a counter balanced motor with a big *** rear tire on the drum does make a difference in the shape of the curve and peak numbers.
Having said that, you underestimate the difference the right pipe can make on a motor. See the below before/after; only change was pulling the V&H Big Shot duals and replacing them with a Drago 2.55 2:1 pipe. Same day, same dyno, etc.; 23HP gain is not too shabby. Not saying replacing your exhaust with a Propipe will result in a 20HP gain, but the right exhaust can make a huge difference..........
File Type: pdf
Old Jun 15, 2016 | 09:16 PM
FlaHeatWave's Avatar
FlaHeatWave
Solid info from djl & ntraindavefl!!
Old Jun 15, 2016 | 09:43 PM
ntraindavefl
Nice pipe swap example by djl.
To the OP, your tq numbers are very good and if your tq peaks at 4-4.5 rpm then I would assume the hp at that rpm is also strong which is the main thing. The hp probably starts to flatten out after 5k and I doubt you and most of us ride there very often. A dyno sheet would help but maybe for street riding the nice tq is the main thing.
Old Jun 16, 2016 | 05:30 AM
martin10's Avatar
martin10
You got less HP than expected but more Torque than expected. Do you like how the bike runs? Let that be whats important instead of the numbers. I would take a few more lbs of torque over a few hp. But thats how I like it. To repeat for the 3rd time. Your pipes are not the best. Want something cheap to try? A dyno tuner on another site has said he gets as much power out of Rush slip on's on Softails as anything. If you still have the stock exhaust find a set of used Rush slipon's for a couple of hundred bucks and try it. Not much to lose
Old Jun 16, 2016 | 06:02 AM
prodrag1320's Avatar
prodrag1320
I would check for sumping.even with your pipes,a breakout having a big wheel,ect,you should be in the 115+120+ area.something dosnt seem to be right
