Going 117", need too make a cam choice...
Nope to crank work, when it lets go (and I'm fairly certain it will at some point) that will be the impetus to get that 124 I always wanted lol.
http://www.hotbikeweb.com/building-stout-twin-cam-crank
Lugging, hole shots, slamming rear brake and locking it up in gear, wheelies, revving to limiter regularly, and other fun stuff will decide the fate of your stock bottom end. With this upgrade, you are essentially doubling the hp over stock. Harley built the flywheel to handle stock type power...
No different that building a house or other structure. Start with a strong foundation and go up from there.
But hey, sounds like you are cool if and when it goes so grip it and rip it!!!
That being said, I have a buddy with an '07 RG 96" that has the usual, cams, pipe etc, and it sees more time bouncing off the rev limiter than idling, more rolling burnouts than you usually see at the drag races over a weekend and it hasn't moved a lick in 80,000 miles of that abuse.
So, ymmmv. I don't plan on abusing it, just like to pass quickly, a few runs up to speed when no one is around etc. I think it will be just fine. And if not, "hello? S&S?"
BTW, I'm guessing your buddy has maybe a 100 hp on a good day in his 96"-not a 117", with maybe 120-130 ft lbs. Apples and oranges.
Not sure you understand the load on cranks-rolling burnouts or rev limiter hits that your buddy does aren't cranks killers by themselves-that's just spinning the motor up with no resistance and the tire spinnin' but hey, gotta justify your upgrade right?
It's lugging, torque hits like hard sticky launches moving a half ton, locking up rear brakes in gear, power up shifts and downshifts loading and unloading the motor, and anything that stresses the crank beyond its capabilities that burns a stock crank-not running at high speed...
As I said, it's your coin and if you good with it, that's all that matters.
Should be a blast to ride, and base your cam profile you choose on the type of riding that you do most of the time, and it should be a real nice upgrade to what you currently have...
So I'm expecting decent longevity. That being said, I have no illusion it's going to live forever. Hell, the sow might eat her piglets on the dyno for all I know.
I'm taking a chance, I recognize it. Oh, not trying to justify it in any way, beyond I want it, can afford it, and mostly, just want it hahaha
However, gov't apparently needs my money for hospitals and road repairs more than I need a fun-time engine lol.
