New Harley Motor
Old Aug 25, 2016 | 10:09 AM
grbrown's Avatar
grbrown
Talking
4-valve heads have been used in autos for many years and almost without exception to provide wide torque curves, from low rpm. It will be interesting to see dyno cuves from bone stock TC and M-8, to compare the two. I predict that once Scott and his team get their teeth into them the M-8s will soon outstrip TCs in all departments!
Old Aug 25, 2016 | 10:11 AM
hrdtail78's Avatar
hrdtail78
That would be HD. I can't find it but I did see they had a cam kit.
Old Aug 25, 2016 | 10:24 AM
djl's Avatar
djl
Not what I am talking about; any HD cam will be an EPA cam. I am referring to a non-EPA cam.
Old Aug 25, 2016 | 10:25 AM
djl's Avatar
djl
I would like to hear Scott's thought about porting the oil cooled head with the new oil passage at the exhaust port and whether or not that presents any issue for the head porters.
Old Aug 25, 2016 | 11:41 AM
todd-67's Avatar
todd-67
This is kinda what I was looking for in the thread that I started. I am interested to see what can be done with the new motor based on the changes. I am also curious about the tuner issues on the new models. Fuel moto says that they can get in with the PV but I have not heard if they have access to the AFR's if they can. That is the big thing that the updated harley tuners cannot change.
Old Aug 25, 2016 | 12:21 PM
hrdtail78's Avatar
hrdtail78
TTS already has a 17 and working on the calibrations. Won't be long. HD has already released the cals. This takes writing in the code to do, and only the tuning manufactures do this. They don't rely on third party to do this for them.
Old Aug 25, 2016 | 01:34 PM
InthewindMN's Avatar
InthewindMN
I was told by the dealer that this motor is counter balanced also. Heard one run but didn't ride it, it did run smooth.
Old Aug 27, 2016 | 03:09 PM
Stopit's Avatar
Stopit
Hopefully when V&H , Fuel Moto and anyone else releases a new head pipe the output end size will fit most mufflers , as is nothing currently other than HD will fit it. Maybe even some adapters for the stock head pipe.
I'm sure the aftermarket is busy working on stuff for the new motor.
Old Aug 27, 2016 | 06:48 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by hardheaded
this is exactly what i was thinking too! don't see how it could make much more power than a evo.
A few things to note.. The port throat area in the intake works out to the equivalent of a 2.2 inch valve.. This means you need a whole lot less cam to get same cylinder fill compared to a 1.8 in a 103.. Even better than a 110 setup.. Second it requires a whole lot less lift to get that same flow.. That means you can have the equivalent valve % lift to flow profile of a radical cam without banging the valves open or slamming them shut.. In other words you can get a Bobby Woods cam without the noise. Also the valve arrangement lends itself to better scavenging..
Old Aug 27, 2016 | 06:57 PM
Stopit's Avatar
Stopit
How long before some one mods the new head for the twin cam motor . . . . . I could see it happening down the road.
