Pushrods adjustment
Old Aug 16, 2016 | 11:34 PM
ScrapingFloorBoards's Avatar
ScrapingFloorBoards
Default Pushrods adjustment
I just did a 107 kit on my SGS and it's got a small oil leak. In trying to track down the leak I collapsed my pushrod tubes to check the o-rings. I decided to check the pushrods while I was in there and found I can't turn the front exhaust. My question is is this normal? I know in the original install I adjusted lash and waited until I could turn the pushrod before putting the tubes back together. Are they just supposed to spin on the base circle or any time they've had enough time to bleed down?
Old Aug 17, 2016 | 03:28 AM
adm's Avatar
adm
Do you know it's on the base circle? Did you set the front cylinder to TDC?
If not, then the pushrod could be on a cam lobe and under pressure from the valve spring....
Old Aug 17, 2016 | 08:15 AM
ScrapingFloorBoards
I have no idea. I'm thinking it's probably on a lobe. If that's the case is it normal to not be able to turn the pushrod?
Old Aug 17, 2016 | 08:46 AM
98hotrodfatboy's Avatar
98hotrodfatboy
If that one lifter was on a cam lobe the valve should be open and there would be no way you could spin the pushrods with your fingers even if it bled down which it will under load.
Most likely it on the bar circle and the lifter bled down which would make if normal.
Real question here is do you have a noisy valve train? If not leave it alone.....
Old Aug 17, 2016 | 03:45 PM
ScrapingFloorBoards
Thanks hotrod. That's exactly what I needed to know.
Old Aug 18, 2016 | 08:11 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
A super fail-safe way, is to adjust the individual valve, one at a time.
IE; When the r/ex is all the way up, the f/ex has to be all the way down, and that, is then adjusted.
If wanted, a 1" dial indicator can be used to witness full lobe lift on the opposite valve, but is really not needed.
Repeat the process until all are done, only rotating the engine after you can spin the pushrod, loading the lifter to .140".
Scott
Old Aug 18, 2016 | 11:05 AM
ScrapingFloorBoards
Thanks for the tip Scott.
Old Aug 19, 2016 | 05:15 AM
Hillsidecycle.com
Sponsor
Happy to share it.
Scott
Yankee Dog
EVO
24
Sep 28, 2024 07:04 AM
cowentz
Mar 9, 2012 08:53 AM
fastmofo01
EVO
Mar 17, 2011 04:56 PM
gregsdart
Nov 3, 2010 02:23 PM
jurob
EVO
Oct 30, 2009 07:16 AM
