Yet another pushrod question.
Old Mar 17, 2011 | 02:25 PM
fastmofo01's Avatar
fastmofo01
Default Yet another pushrod question.
Ok, im sure this is a re post but after searching forum for last 20 minutes, I havent got my question answered directly and some confliction. So I appologize.
Ok, I'm putting everything back together and have my new v-thunder pushrods. To adjust them, I have the lifter for the one I'm working on in the lowest cam position.
Now is proper way to adjust push rod to extend so there is no up or down movement, but still spins freely, and then adjust another 3 turns out? and repeat once lifter is bled?
Or do you not want the push rod to be able to spin freely?
Again, I appologize because im sure this is a re-post, but thank you in advance for help!
Old Mar 17, 2011 | 02:31 PM
RidemyEVO's Avatar
RidemyEVO
Basicly the one your going to adjust snug it up so it spins and there's no up down movement and then do the 3 turns.
Old Mar 17, 2011 | 02:38 PM
woodnbow's Avatar
woodnbow
Pretty much nailed it. I just put in a set of those rods on top of my new EV46. extended them until I had zero lash, NO up and down but the rods will still spin freely. Then extend 3 turns, (or 18 flats) and lock the lock nuts. Do the intake first and then the exhaust on say the front cylinder and then llow the lifters to bleed down before moving on to the other cylinder. You can tell the lifters are bled when you can turn the pushrod with thumb and forefinger, not easily really but they'll turn.
The Vthunder rods are 24tpi so 2.5 turns gives you roughly .100 inches, v thunder wants 3 turns so you're into your lifter travel a bit more, about .120 inches. I followed the directions and this is the quietest Andrews cam I've ever heard..
Old Mar 17, 2011 | 02:59 PM
fastmofo01's Avatar
fastmofo01
After lifter is bled down, you turn to zero lash, plus 3 turns again, Right?
Old Mar 17, 2011 | 03:43 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You are not listening...
Lifter on low part of cam.
Adjust so there is no up and down movement of pushrod.
Adjust 3 Turns.
Tighten lock nuts.
That is it. No more adjustment. Leave it alone. Done. Finished. Quit.
Do not rotate the engine until the lifter bleeds down.
Old Mar 17, 2011 | 04:13 PM
fastmofo01's Avatar
fastmofo01
Thumbs down
Thank you all! Sorry for being a tard!
Old Mar 17, 2011 | 04:24 PM
woodnbow's Avatar
woodnbow
LOL! Dan knows how to 'splain it. Mo' simpla mo betta... Good luck with your project, when you're done you'll say "damn, that was easy!" ;-)
Old Mar 17, 2011 | 04:56 PM
RidemyEVO's Avatar
RidemyEVO
Adjust 3 Turns.
Tighten lock nuts.
Ya but
lmz5150
EVO
Sep 27, 2018 05:35 PM
swhitinger
Nov 5, 2013 04:27 PM
AllenW
Exhaust System Topics
11
Apr 23, 2013 08:33 AM
ionhd
Mar 3, 2011 10:42 AM
96roadking
EVO
May 6, 2010 05:05 AM
