HELP! Am I ****ed??!!
Old Aug 21, 2016 | 02:28 AM
Badillac's Avatar
Badillac
Default HELP! Am I ****ed??!!
Riding home,old lady on back doing 80-ish mph and something knocked a hole in my oil pan (2000 Fxdwg) and I didn' t know right away.Started hearing my top end getting louder (valve rockers) looked down oil light on! Pulled over immediately,shut it down and watched about half a qt **** out of the front of my pan! Checked level,ZERO!!!!!! Nothing left,not a drop! I never heard rod knock etc,and pulled over immediately when I heard top end clatter.Is my engine ****ed?? Should I just put a new pan on fill her up and see what happens?How tough are these twin cams in a situation like this??
Old Aug 21, 2016 | 02:41 AM
PSRumors's Avatar
PSRumors
Only one way to find out. Like you said, put a pan on it, fill it up and see what she does
Old Aug 21, 2016 | 04:02 AM
Stiggy's Avatar
Stiggy
I doubt that you hurt it if you shut it down right when the lifters failed.
Old Aug 21, 2016 | 07:02 AM
ntraindavefl's Avatar
ntraindavefl
It would take some miles to create damage. You're probably good.
Old Aug 21, 2016 | 07:08 AM
Iceman24's Avatar
Iceman24
Like other suggest...pan it, fill it & try it. Worth a shot and you're not tearing everything apart for not.
Old Aug 21, 2016 | 07:09 AM
screaminroadking's Avatar
screaminroadking
Ouch. As long as you didn't travel a bunch of miles with no oil, you should be ok. The biggest killer to that would be the heat generated. Good luck.
Old Aug 21, 2016 | 06:39 PM
SiggerTX's Avatar
SiggerTX
Refill, prime, listen. You should probably check compression as well.
Old Sep 5, 2016 | 10:18 PM
Badillac's Avatar
Badillac
UPDATE... Well,have her back together with a new pan,gasket,and she's full of oil.She sounds,and runs fine!! No click/clack,knock,NADA!! Still have to take her for a long ride to clear my head of all doubt,but I'd say she made it out unscathed! Can I get a HELL YEAH!!?? She didn't let me slide without a fight though.While on a short shake-down ride yesterday after getting her going my gauge console kept cutting in and out.I got her home,and as I suspected the damn voltage regulator took a dump! Replaced that,and a broken tail light bulb,plus a couple fuses due to 18v running thru system when regulator crapped out. NOW... She's done!
Old Sep 5, 2016 | 10:25 PM
Lou'sUltra's Avatar
Lou'sUltra
That's a relief of your mind!
MrWhitaker
May 26, 2017 03:22 AM
welder1212
Apr 27, 2014 04:45 AM
e7bin
Aug 26, 2012 10:30 AM
PapaTravis
Sep 28, 2008 07:13 AM
mayfiebl
Exhaust System Topics
11
Oct 5, 2007 08:06 AM
