2003 dyna wide glide won't rev
Old Sep 18, 2016 | 12:59 PM
Edjet93's Avatar
Edjet93
Stage II
Default 2003 dyna wide glide won't rev
So I recently purchased in screaming eagle adjustable pushrods camplate and oil pump. Since then it ran well for a few weeks then the crank position sensor went bad and it wouldn't start. So I replaced the cam sensor and its never had as much power since then. And now is gutless and will not rev past 4000rpm it doesn't miss it just acts like it hits a wall. Any help would be greatly appreciated. Anything to avoid going to the stealership.
Old Sep 18, 2016 | 03:04 PM
Nitro 54's Avatar
Nitro 54
Is your butterfly opening up in the throttle body when you open up the throttle wide open?
Old Sep 19, 2016 | 08:52 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Pull the crankcase drain plug and measure, in oz., the amount of oil that drains out.
Let us know your findings.
Scott
Old Sep 19, 2016 | 07:00 PM
Campy Roadie's Avatar
Campy Roadie
Improper oil pump reassembly will cause the motor to sump. Like Scott said, I'd look there first.
Old Sep 20, 2016 | 06:01 AM
Hillsidecycle.com
Sponsor
...........and if the crankcase, is becoming flooded, 98.742% chance that the O-ring between the oil pump and crankcase has been torn, or harmed in some fashion.
Scott
TravisD27
Oct 25, 2018 07:10 PM
matthew seiller
May 10, 2018 10:32 AM
mike beedy
Jun 21, 2014 07:07 AM
pimpygrub
Exhaust System Topics
Feb 25, 2010 06:29 PM
ken10652
Sep 16, 2009 06:51 PM
