Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
You can bore your OEM cylinders to 3.937"(107").
We were one of the very first shops in the country to start doing so back in 2007, going to 107", and we were boring the 88" to 98" in 2006.
Many folks scoffed at this, but time has shown otherwise.
Scott
The 110" kit, put together right, can be a runner. A dealer tech on another forum reports 80 kits, 110s and 117s, installed to date with only one having an issue.
