Low - Mid Cam Choice for 103
Old Oct 19, 2016 | 09:05 AM
rauchman's Avatar
rauchman
Thanks for everyone's input. I think for now I'm going to find a local place to have a full tune done. I'm running an FP3 currently and I don't know, but I think the tune isn't all it can be. Any recommended tuners in the northeast NJ area?
Old Oct 19, 2016 | 09:09 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
That Fuel Pack won't cut the mustard.
We'd tune it with Direct Link, if you brought it up.
Scott
Old Oct 19, 2016 | 09:13 AM
djl's Avatar
djl
The FP3 is limited in functionality. Replace it with Power Vision or TTS Mastertune. The below link will open up a map with tuner locations; maybe you can find one there.
https://www.zeemaps.com/map?group=1976040#
Old Oct 19, 2016 | 09:51 AM
qtrracer's Avatar
qtrracer
Depending on things either a TTS, PV or DL are all much better options for your case . If you are a fiddler and like to try to tune stuff yourself and don't care that you'll never get it right, LOL, the PV is the most end user friendly. The TTS is what many many many professional tuners will recommend. The Direct Link that Scott referenced, I believe , you just buy the "key" at less than half the price of buying a tuner. The shop then tunes your bike and should give your "key" and a flash drive with your original tune and your current tune. You can go to any DL shop and get your bike tuned. You pay the DL shop for their labor. It's getting more popular everyday. If I have it wrong I apologize and I hope someone chimes in and sets me straight on the DL.
Old Oct 19, 2016 | 11:43 AM
rauchman's Avatar
rauchman
Scott
How long would a tune take? I think you're about 3 hours from me. Also, ballpark on cost?
Old Oct 19, 2016 | 07:05 PM
Sisu's Avatar
Sisu
Originally Posted by 05FLHTC
I've installed the 57 in stock 103 with + 4 key...helped with pushing the Tq to left
It's only about $50. for the +4* sprocket and it worked for me.
Old Oct 25, 2016 | 10:20 AM
KumaRide's Avatar
KumaRide
Maybe I missed this info:
- What exhaust are you running?
- What mufflers?
Definitely replace the FP3
Having the proper mufflers will provide more low end tq, especially with a tune. Crusher Mellows, Fatshotz, Fullsac baffles (louder then the other two mentioned).
Rather then changing out cams, spend the money on mufflers and tuner. The tuner needs to be replaced anyway. Maybe mufflers too, depending on what you have. Consider TTS or PV. Lots of 57 maps for both of these tuners.
Stock decatted header and FM Jackpot mufflers getting 95tq @ 2500 rpm. The diff of another 5tq at 2500 rpms is something that would not be obvious by sop. What Im sayin is, dont chase numbers too much. Unless of course, it matters to you and you have money to spend.
https://www.hdforums.com/forum/attac...-img_2967a.jpg
Old Oct 25, 2016 | 10:52 AM
martinj's Avatar
martinj
- What mufflers?
While the exhaust can have a positive effect on the low end torque, the camshafts are the deciding factor in how much torque an engine is actually capable of building, and at what rpm. Here's a dyno chart that compares the 57H cam with a cr570 cam. In both instances the bike had Vance & Hines Power Duals, Kuryakin Street Sleeper III ac, and a .030 head gasket, dynotuned with a Powervision. Around 10 lb/ft more torque at 2k rpm, with only a couple of horsepower lost at the top:
I'm betting one could really feel the difference off the line between these two setups.
As KumaRide says, get rid of the FP3....
Old Oct 25, 2016 | 11:03 AM
KumaRide's Avatar
KumaRide
Agreed. But I am looking at it from the "best bang for the buck" perspective and taking a methodical approach. He would need a tuner anyway, and possibly mufflers also. Then if its not enough for him, then cams. If not enough, then headpipe? Its only money...
Old Oct 26, 2016 | 12:28 PM
rauchman's Avatar
rauchman
- What mufflers?
Running V&H Pro Pipe. I'd rather not spend money on another exhaust. For the cost of any incremental gains, I'd rather just get the bike professionally tuned. I don't think I'm giving up all that much in the exhaust.
