Stock chamber volumes
I don't mind the sarcasm...but at least get the 'facts' straight.
The 'rule of thumb' I was requesting was from those that have done this enough to give a ballpark number given a 103" starting point... i.e. if you shave .020" you bump compression by about +.2:1, .040 if you want +.5:1,etc.
Similar to the question...how much do you bump compression switching from a .045" head gasket to a .030? but without having to input every (known) detail into a formula.
I don't know about you but I want to know precisely how much to remove from a head surface to achieve a target chamber volume so that my calculated CCP and corrected CR are as accurate as possible. Cylinder volume, head gasket thickness, chamber volume, piston dome volume, deck height and cam intake close event are all elements of that calculation. I have found that using the information provided in my previous post to be the most accurate when determining how much to remove from a cylinder head to achieve the compression targets. So I thought you might find it useful but if not, please disregard. You are the one with questions, I am one of the guys that has "done this enough" trying to answer........
At the end of the day, you have to trust the head porter to get the chamber volume right and equalized between both heads. I just use the previously provided information to estimate the chamber volume requirement to pass on to the head porter.......
Example use case...changing cams and the new cams won't run well on stock compression of, say 9.0:1. The recommended compression is >10.5:1, so nothing extreme and still in the 'bolt in' range.
Pistons, cylinders (by way of deck height) and head volume all play a role comprising the combustion chamber... some of them, like moving from a dished piston to a 6cc dome, provide big jumps, whereas setting a zero deck height or shaving a head .020" are more for fine tuning.
You wouldn't want to shave .5" from a head to make up 1.5 points of compression, at that point it would be better to change pistons. So, where do you draw the line from one to the next?
I didn't struggle with high school or college level geometry...but that only gets you so far in understanding what's practical and more importantly reliable, in the way its applied.
We left base gaskets out of the discussion and they can play a role in this issue as well. There are a lot of moving parts and getting the compression right is probably the most important of them all and one that is overlooled by many but truly, it's not rocket science and certainly easier than college geometry...........
All other combustion chamber with different surface areas at the flat will have different numbers. Some will be pretty close to this but Hemi chambers without squish will be bore area x height..
Bottom line, cc the heads once completed with the valve job, and any chamber modifications, and machine the gasket surface as needed for the given cubic inch, and camshaft.
Scott
