how to figure Compression ratio
Old Nov 26, 2016 | 09:18 PM
pdevore's Avatar
pdevore
Default how to figure Compression ratio
I am trying to figure out the compression ratio based on components selected.
The plan is a 107" with S&S cylinders, S&S CP pistons, S&S 89cc heads. I don't know which gasket yet because I need to find the compression ration for both .030 and .045
Is there a site that I can input this info and find where I would be at?
Thanks.
Old Nov 26, 2016 | 09:56 PM
Longridertx's Avatar
Longridertx
Here you go: http://bigboyzheadporting.com/TwinCamComp.htm
Old Nov 27, 2016 | 06:24 AM
prodrag1320's Avatar
prodrag1320
youde do a lot better boring your cylinders & having your heads done.
Old Nov 27, 2016 | 04:32 PM
pdevore's Avatar
pdevore
What is the difference from buying a set of 107" cylinders and boring my factory ones?
I understand that many shops can flow a set of heads better than the S&S ones, but if I have to have them decked I plan to have these worked also.
Thanks
Old Nov 27, 2016 | 05:35 PM
djl's Avatar
djl
Originally Posted by pdevore
What is the difference from buying a set of 107" cylinders and boring my factory ones?Thanks
Cylinders and pistons purchased off the shelf are manufactured to +/- tolerances; they are not a matched set. If one happens to purchase a set of cylnders that is near the + side of the tolerance, i.e. max bore diameter and a set of pistons that is near the - side of the tolerance, i.e. minimum bore diameter, piston to wall clearance may be out of spec. Not to mention checking the bore for trueness. Always better to have cylinders, used or new, bored/honed to fit pistons which may require ordering .010" or .020" O/S pistons. Only way to guarantee precise piston to cylinder fitment and a true cylinder bore.
Old Nov 27, 2016 | 05:57 PM
pdevore's Avatar
pdevore
I understand that, I was planning on having the jugs honed and pistons matched to the cylinders. I thought Kirby was saying that its better to reuse my original than buy any other jugs.
Old Dec 1, 2016 | 06:18 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Thanks.
To help answer the question.........what cam?
Scott
Old Dec 1, 2016 | 07:32 AM
prodrag1320
agree with scott,checking staic compression is easy,but cams must be brought into the equation for corrected compression,this is the figure your looking for (& don't go by advertised compression of you pistons,always cc the heads and find out the true dome cc of pistons being used)
Old Dec 1, 2016 | 07:59 AM
mattVA's Avatar
mattVA
It's counter intuitive to buy off the shelf $$$ S&S cylinders and pistons to only have to then do further work. The pistons and cylinders from S&S will likely be right in spec from them. As Kirby has mentioned your money is much better spent on a good set of pistons and boring your current, seasoned cylinders to match and doing work on your current heads. Just make sure you go to someone that knows what they're doing. New fresh cylinders you're gambling they'll stay round and won't shift. Your old cylinders have already been heat cycled so they're less likely to change. On the flip side the S&S cylinders are designed to be run at 107" or 3.937" bore whereas your stock cylinders weren't. Just something to consider.
You'll also find if you go piston shopping you can get the exact compression ratio you want for the cams you select. Those 89cc heads are pretty darn big for a 107 you'll probably find you want something down in the 83-85cc range once you start playing around with the calculator. Most pistons will put you 0.005-0.008" in the hole but you won't know for sure unless you measure.
As someone who went down the S&S off the shelf path and is now having issues if I were to do it again I'd use my stock cylinders and buy the pistons I want. It's more work finding shops you trust but less money.
Good luck with your decisions if this is your first time doing this it can be overwhelming but there's a lot of info out there. As was mentioned above you really need to find a cam you like first, or a range of cams that are similar, and what compression they like to be run at and go from there. The cam dictates what compression you should be running and consequently which pistons, which head gasket, and what kind of headwork.
Old Dec 1, 2016 | 08:31 AM
djl's Avatar
djl
That is not clear in your OP. Any off the shelf cylinder should be checked for a true bore. If using off the shelf new cylinders, I make it a practice to order .010" or .020" OS pistons so even if the new cylinder bore is not true, it will be after boring. Additionally, I can set piston to cylinder wall clearance where I want rather than leave it to chance. Of course, if "seasoned" cylinders can be bored to the required spec to fit new pistons, why spend the $$ for new cylinders? Not so much an issue of one being better than the other to me but more an issue of cost.
