Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
OK thanks for the replies. I did want to ask the dealerships because they told me I had to use the cams that came in the 117 kit, & I wanted to use the bigger cams I already had in my bike ( 1 guy told me it would cause the bike to have too much compression SMH) so I called & asked if I could stick 117 jugs on my CVO if I already had the SE585 cams & they said it would be fine.
So I am selling my buddy the cams ,lifters, bearings & gaskets out of the kit & didnt know if he could use the jugs & pistons also
The problem with the 259E is that it needs compression.. If your buddy uses that cam to build a 110 / 107 with ported heads, I'd bet the build is a screamer.. Have em set the CR to somewhere between 10.8 and 11 to 1..
You'll be looking at the guy's license plate a lot..
I am installing them myself & I dont care about the warranty. LOL It was cheaper to purchase the kit than get parts separate.
Just saying your buddy can buy the 110" cylinders and pistons for about $1100, add your cams, lifters, bearings and gaskets that I am sure you will sell cheap, have his heads ported and set up for the compression per bwoltz's post and have good runner.
I believe the only way he could use the cylinders is to open up the bore on the case.
