Throttle Body experience needed....
Old Feb 5, 2017 | 04:40 PM
TriSum's Avatar
TriSum
I wouldn't either! But 3 to 6 hundred, I might depending on where it is in the curve.
David
Originally Posted by 13RoadKing
I wouldn't spend $3k to get extra 5hp.
Old Feb 23, 2017 | 05:54 PM
johnwesley's Avatar
johnwesley
David
any my new info on the build? I'm letting you try it out first
Old Feb 24, 2017 | 12:22 PM
TriSum's Avatar
TriSum
All parts are in, just waiting on the editor to schedule an install date.
David
Old Feb 25, 2017 | 03:34 PM
Skully10's Avatar
Skully10
Scott,
What kind of numbers could one expect with the set up you described above? I have a 2015 Road Glide with just an upgraded SS 551 cam ( Didn't notice much gains over stock cam). I have a V&H power dual header with Rhinehart slip ons and a Direct Link tuner. Very disappointed in the final # gains after dyno tune.
Old Mar 30, 2017 | 07:06 PM
TriSum's Avatar
TriSum
So....... got everything installed;
100" S&S kit w/ ES 585 cam's.
10.8:1 compression
MCE fully ported heads, 1.94/1.57
D&D Fatcat exhaust
51mm HPI TB w/ 1.71 intake to match the heads.
Dnojet PC5
Got everything together, but having a stumble issue at very light throttle while cruising and occasionally a bad stumble on take off. Tuner can't figure it out as it doesn't seem to be fuel related, (get's worse with heat).
Tuner put stock TB back on and has been able to aleviate the light throttle stumble while cruising, but still has the occasional off idle stumble, (bog) when taking off. Not that it was the HPI TB causing this he just eliminated it to try and fix the issue.
Here is the graph with the stock TB. It looks to me as if it is nosing over around 4600rpm and needs the larger TB to make the number up top.
Not sure if the PC5 can't make enough adjustments for all of the mod's done and I may need something more like the TTS to fix the stumble or if something else is happening. Interested in your opinions on the upper end power with the 585 cam's. I thought it would pull a little harder on the top end. ?????
Thanks,
David
Old Mar 30, 2017 | 08:58 PM
Max Headflow's Avatar
Max Headflow
Dump the PC5.. With those heads, 51 tb, and a good tuner, I'd bet you pick up 5 more hp..
Old Mar 31, 2017 | 07:32 AM
flanigans45's Avatar
flanigans45
Sounds like the Accel Enrichment adjustment is to Rich / Temp goes up need less fuel. Use A gas analyzer . Should be about 13-1 ratio daring acceleration.
Old Mar 31, 2017 | 04:12 PM
TriSum's Avatar
TriSum
I hope more than 5, but we'll see.
I asked about that and he said it was good. He thinks it is electrical, (TPS sensor has a glitch or something like that.)
kcollins
Apr 22, 2017 07:11 PM
adm
Engine Mechanical Topics
22
Jul 26, 2016 07:20 AM
TODDNVAL
Nov 19, 2008 10:41 AM
dog116929
Exhaust System Topics
Jul 17, 2008 05:27 PM
razehog
May 11, 2007 02:47 AM
