Need some help.
Old Jan 21, 2017 | 07:54 PM
Baddass1999's Avatar
Baddass1999
2nd Gear
Default Need some help.
Replace head gasket and trying to install heads. But I moved bike and changed cam position from tear down position. How do I install heads and push rods to proper position without taking off cam cover.
Old Jan 21, 2017 | 08:26 PM
Max Headflow's Avatar
Max Headflow
You can install the heads no matter what the crank position is.. On pushrods, with the plugs out, get the rear wheel off the ground and place MC in top gear. Using your fingers feel the intake and exhaust lifters on one cylinder.. Rotate the motor by bumping the rear wheel until you get to a point where while one lifter is moving down the other is moving up. When you have a point where they are at about the same height, install the other cylinders pushrods and rocker arms. Then while looking at the rocker arms you just installed find the point where one rocker is closing and the other opening by turning the rear wheel. Assemble the pushrods and rockers on the other cylinder..
Old Jan 26, 2017 | 12:54 PM
Lunchboxx's Avatar
Lunchboxx
Or just use you fingers on the lifters and when both are in the same position at there lowest point of travel, install pushrods and rocker arms and go to the second cylinder and do the same. at the lowest point of travel on both lifters they should be on the base cirlce(both valves closed)
Old Jan 26, 2017 | 07:53 PM
Baddass1999
2nd Gear
Default Th
I will try, anymore info is greatly appreciated
Old Jan 26, 2017 | 07:56 PM
Baddass1999
2nd Gear
Default One more
So do i need to take apart second head, because both say install lifters and pushrods on second cylinder installation.
Old Jan 27, 2017 | 09:59 AM
Lunchboxx's Avatar
Lunchboxx
Do one cylinder at a time. When I did mine I started with the front and moved to the rear.
Old Jan 30, 2017 | 06:51 PM
Baddass1999
2nd Gear
worked out great, rear valve cover was up a little as i tightened it down, but it went down smoothly. Finished and bike started on first hit. Thank you much.
CookUltraClassic
May 5, 2019 02:00 PM
iamron6113
Oct 21, 2014 04:35 PM
major105bc
Engine Mechanical Topics
Jun 24, 2014 06:21 AM
harleylay
Jan 31, 2011 09:34 AM
jlb0038
Exhaust System Topics
Jun 13, 2010 04:22 PM
