Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I have a 04 ultra with 40K. Starts and runs great. Pull out go a block and when you back off throttle will vibrate like mad, I pull in clutch and coast or come to a stop same. Accelerate clears right up "no I cant just always accelerate". Any ideas?
Doesn't sound like crank runout to me. I would be looking at drive train and check everything starting with the primary; pulleys, belt, axle bolts, steering head bearings, clutch, swing arm bushings, etc.
Any modifications? Did this just start, like one day all OK but the next not or did the problem develop over time?
