SE adjustables 24 TPI
Old Feb 11, 2017 | 08:50 PM
Eastcoast Jim's Avatar
Eastcoast Jim
You are welcome - 0.130 should be good - I have Woods TW 6-H cams - and run a little more pre load - Eastcoast Jim
Old Feb 11, 2017 | 11:42 PM
98hotrodfatboy's Avatar
98hotrodfatboy
20 flats is a perfect preload on 24 tpi..... Which =.138"
Old Feb 12, 2017 | 03:12 PM
rsking45's Avatar
rsking45
Sorry I thought this was a S&S conversation
my bad,
Old Feb 12, 2017 | 03:23 PM
Uncle Fuzzy's Avatar
Uncle Fuzzy
SE=SCREAMING CHICKEN (EAGLE)
S&S is a different animal all together.
Not all SE pushrods are 32 TPI.
I believe the newer tapered are.
The older are 24 TPI which is what I have.
Believe me, I counted the threads under a magnifier.
Old Feb 14, 2017 | 08:34 PM
SgtMic's Avatar
SgtMic
I have new SE tapered and they are 24 tpi.
Old Feb 18, 2017 | 06:52 PM
Uncle Fuzzy
Here's one more question.
My upper pushrod covers seem very loose.
They are the longer ones that mate with the shorter lowers.
Mating surfaces look identical to my stock ones.
If you rotate the spring lock with your fingers they pop out.
O rings are installed in the tappet block...first thing I checked.
Any ideas?
Old Feb 18, 2017 | 07:42 PM
98hotrodfatboy
Some of the locking sleeves have a slight flare at on end make sure that is up. Or make sure the straight one is down against the spring loaded collar..
Old Feb 18, 2017 | 07:47 PM
Uncle Fuzzy
The locking sleeves came right out of my stock covers and into the shorties...
Same way
Perplexed..seems like they'd pop off it you looked at em hard.
Old Feb 18, 2017 | 07:52 PM
98hotrodfatboy
The only other thing it can be is the the lowers are shorter like you said and with that the spring tension will not be the same as the others. If they are shorter the spring pressure will be less..... did you get new locking sleeves with the new tubes?
Old Feb 18, 2017 | 07:58 PM
Uncle Fuzzy
No sleeves.
Just the upper and lower covers.
Maybe I'm missing parts
