Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Am I calculating correctly? 1 turn = .024 so 4 turns would =.096? ?
I seem to remember someone saying to set them deeper than .100 to reduce valve train noise with bolt in cams (Andrews 48h)
I have the rear set to 3.5 right now and bleeding down.
I use 15 flats for 0.100 preload = 2.5 turns - 22 or 23 flats for 0.150 preload if you're running aggressive cams - that's where I have mine set. count the flats, I think it is more accurate. your 3.5 turns = 23 flats = 0.150 you might not need that much for a 48 or maybe you do - Eastcoast Jim
