High Compression Spark Plug Cross Reference
Old Mar 4, 2017 | 06:37 PM
cvaria's Avatar
cvaria
Default High Compression Spark Plug Cross Reference
I bought these high compression plugs for about 10 bucks because that's what the heads and overall collection of parts require per HD. i don't want to pay the $20 retail for these on the next go round so i'm looking for and up to date cross reference table . i found the attached but. the models don't seem to line up with the current last few rounds of hd models.anyone have a link?
32186-10/(now)31600105
File Type: doc
Old Mar 5, 2017 | 08:22 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Never heard of a High Compression spark plug. Care to elaborate on the difference compared to regular spark plugs?
Old Mar 5, 2017 | 08:34 AM
TXCHOP's Avatar
TXCHOP
The heat range is different is all.
Not necessarily needed. I have used stock plugs for everything from bone stock 88's to 165HP 117 engines with out any issues.
I dont know the exact heat range of the plug listed but the Vrod plug will also work.
Also look at NGK DCPR8EIX. That one heat range off of stock and also iridium.
Old Mar 6, 2017 | 09:35 AM
cvaria's Avatar
cvaria
Thank you i will look at those as well
Old Mar 6, 2017 | 11:56 AM
HotRodNut's Avatar
HotRodNut
I don't want to hack your thread but you seem to have knowledge of the H-D plugs.
I have purchased the 3160105 you mentioned for my 117 ci in LRS and also the 31600106, (std heat range). Any idea why the 31600105 has a stamping of 31600104 on the shell casing and the 31600106 has 31600103?
Also the color is not gold, although the porcelain insulator does have the Screamin' Eagle on it.
Old Mar 6, 2017 | 02:39 PM
stal94gt's Avatar
stal94gt
I would make sure you need to run colder plugs before sticking them in. When pulling your old plugs inspect the electrode to see if the heat mark goes over half way. Also inspect the strap for the timing mark. Ideal timing mark should be centered on the 90 degree bend. If it is past the 90 than some timing should be pulled out.
Old Mar 6, 2017 | 02:43 PM
prodrag1320's Avatar
prodrag1320
Run the regular heat range,you dont need to go with different plugs until your running way too much compression for a street motor.we ran colder,race plugs in our P/G bikes,but we were also running 18.0-1
Old Mar 6, 2017 | 03:11 PM
Gozzie's Avatar
Gozzie
That's some good info. Never knew that.
nosinjcted
May 19, 2022 04:26 PM
cruzmisl
Jun 25, 2014 04:22 PM
HDF Tech
Engine Mechanical Topics
May 2, 2012 06:35 PM
kenward
Jul 31, 2009 08:42 AM
flynavy
Exhaust System Topics
Oct 26, 2007 06:17 PM
