Carb rebuild failure, help please
Old Mar 7, 2017 | 11:40 AM
triple604's Avatar
triple604
6th Gear
Default Carb rebuild failure, help please
Posted in carb section didn't get much reaction trying here
Pulled my carb and intake manifold, did the gaskets, put it back together, fires up right away idles really nice, roll it outside click it into first and the more throttle I give it the more it tries to die
in nuetral it idled fine and I can rev the engine no problems, accelerate pump works fine
Old Mar 7, 2017 | 05:52 PM
13RoadKing's Avatar
13RoadKing
Not sure if it happened with your carb. Carb cleaners make 2 mistakes very often:
They don't clean idle jet and holes next to throttle edge.
In your case:
check fuel level and keep clear tube attached while you ride.(that is kind of dangerous) you'll be able to stop any time and check fuel level. you can attach mirror and see level while riding (dangerous!!!)
triple604
Carburetor Related
Mar 7, 2017 04:20 PM
All Aces
EVO
16
Jul 12, 2014 06:27 AM
CaptnAl
Nov 20, 2012 05:41 AM
johangastorp
EVO
25
Sep 12, 2012 11:46 AM
timberwolfz28
Aug 3, 2008 06:46 PM
